Question about Tissot T-Touch T33759851
Tissot t race battery replacement
Change battery
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Apr 22, 2017 | Tissot Watches
Battery replacement
  • Open case
  • Remove old battery. Check to be sure it is same type as new battery.
  • Install new battery. Be sure it is correctly seated and clamped in place.
  • Close case
  • Check operation and settings
Jun 26, 2016 | Tissot Mens T0484172705703 T-Race Quartz...
How to replace the battery on tissot1853
You Can see the video in my blog how can change the battery from Tissot Sea Touch.Is all the same.
www.watch4maker.com
Aug 09, 2014 | Tissot T-Touch T33159851 Wrist Watch
Battery replacement is it a dealer only job?
This is a Myth my friend.Anyone can change a battery on Tissot T Touch.The First models have 2 steps the Battery Replacement and Synchronization.After the Tissot Expert add the Reset as third step.
In my blog i have instructions with video how can you do that.
www.watch4maker.com
Nov 24, 2013 | Tissot T33.1.588.51 T-Touch Dial
Can not regulate my tissot visodate seastar automatic
the problem is the air spring on the balance wheel it can be 1 or 2 things wrong spring stuck together with oil spring got crossed or if it's been neat a magnet, needs jeweler repair shop
Mar 15, 2013 | Tissot T Classic Seastar II T55.8.283.11...
Tissot t-touch battery problem
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
Jan 30, 2013 | Tissot T-Touch T33159851 Wrist Watch
Hi I have a Tissot T Race watch (model # T011417 A). It is still under gurantee, but I noticed that every 24 hours, there is a delay of 5 seconds in the watch; in other words (1 minute and 10 seconds...
I agree with the repair service, in that it probably is not a big deal, but since it is still under warranty, I would contact Tissot at the following to get their professional advice on their product.
http://www.tissot.ch/?mod_contact
Best wishes.
Aug 12, 2010 | Tissot T Race T90444631 Watch
Bracelet
srevice center for tissot watches here in the philippines is only at timeline...g/f farmers plaza cubao,q.c. its fronting gateway and araneta coliseum.
Jul 29, 2008 | Tissot T-Touch T33759851
Tissot T-Touch T33759851 Logo
61 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
