Question about General Electric E850 Digital Camera
Shutter malfunctioning I bought a new camera and within a month the shutter has started to malfunction. It doesn't shut completely when switched off nor does it open completely when switched on. If you touch the shutter manually it opens. Is there a way to fix this problem myself? Since my warranty card is not signed or date of purchase mentioned by the dealer I bought it from!
    Genius:
  • 1,066 Answers
No...return it for repair or replacement.  It may simply have dirt in the lens cover.  Digital cameras do not have shutters.
Posted on Mar 12, 2009
Keeps indicating error 20
That error code indicates a mechanical malfunction. either a problem with the mirror box, or a shutter malfunction is the usual cause - the shutter being more likely
Mar 10, 2013 | Canon EOS 60D Digital Camera
Nikon d90 error showing and doesn't ftre
On page 256 of the D-90 users manual it says that ERR indicates a camera malfunction that can be cleared by releasing the shutter. On my D-90 when this occurs, I have to turn the camera off to make the shutter release. Sometimes, but rarely, I have to remove and reinstall the battery to get the shutter to release.
The manual also says that if this error occurs frequently or persists to contact n authorized Nikon service center. I suggest that you contact Nikon tech support at www.nikon,com before you contact a service center to see what tech support advises. I have heard of people resolving this problem by upgrading the firmware (camera software). Nikon tech support can tell you if this will help.
Feb 03, 2013 | Nikon D Cameras
Shutter doesn't shoot on nikon d7000
Are you getting an ERR in the control panel? If so, it's an indication that the camera has malfunctioned. Here's what my D-90 manual says to do. It may work for your D-7000.
Jan 18, 2013 | Nikon D7000 Digital Camera
The mirror in the my nikon d 70 is stuck in the middle and gives me message ERROR and LO F4 when i push to take a picture.
Try setting the camera to the 'M' manual mode and remove the lens. See if the shutter will fire and complete the cycle. You should have a memory card installed or have the menu set to 'No CF card'. If the shutter does fire, then re-mount the lens and return the mode to 'P'. If it does not fire the shutter, then it is likely the there is a malfunction with the mirror box components (a broken spring). That type of repair is not a DIY and will require a complete dis-assembly of the camera.
Jan 31, 2010 | Nikon D70 Body Only Digital Camera
Slower trigger time then when I first bought it! Really SLOW!!!!
Get in front of the camera and watch the lens. See if you can tell when the shutter is opening and when it closes. I suspect your camera is taking a very long exposure, either because of the settings you made or due to a malfunction of the shutter mechanism. Observation of the shutter may be enough for you to see what is causing the problem. Long exposure = whiteout.
Oct 07, 2009 | Moultrie MFH-DGS-200 Digital Camera
The lens will not go in. seems like the shutter is stuck. when I press the power button, it feels like the camera is trying to shut the shutter but it cannot. then is says to turn the power off and try...
The problem is in your camera optical lens unit, actually the zoom motor start malfunction and this problem appears here is the part number and the description of the LENS:
Part No. Description
1-788-363-11 OPTICAL UNIT (ED13A)
Change the given part and your camera work fine again.
Thanks for using fixya.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Shutter won't release
If the lighting is low and shutter speed is set for a long period of time its the function of the camera taking the picture. If it is a malfunction of the shutter take it in for cleaning you might have foriegn material stuck in your shutter mechanism
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D70 Shutter Problem
I have a Nikon D70 which failed completely but exhibited similar symptoms.
I was fortunate in that I had taken out 3 years free warranty at the point of purchase and therefore saved the £90 (sterling) repair cost.
Nikon cameras are designed to be robust and should give a lifetime's service. Most should give 150,000 shutter actuations.
There is a piece of free software available on the Web that will tell you how many actuations were recorded on your recent photos.
Unfortunately, in the fast moving world of digital cameras, the value of a 2nd user older camera is very low.
You need to decide if you were outgrowing this camera body and want to replace it with something better or whether you would be lost without it. My repair took more than 1 month and I was not able to take any photos during his time.
I hope this helps.
Jan 15, 2009 | Nikon D70s Digital Camera
Shutter release problem
Try removing the lens and the battery and leaving it for 24 hours - this can happen when the gremlins get into the works !
Jul 24, 2017 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Bronica SQ-Ai shutter problem
There could be a number of issues with this problem. Make sure the contacts at the rear of the lens and those on the body that connect with those on the lens are clean and straight. If so, the problem may be in the shutter within the lens. There is a magnet inside the shutter that sometimes becomes contaminated and fails to hold the shutter blades open for the selected shutter speed. The face of the magnet may need to be cleaned. There are also timing switches that sometimes go bad or need adjusting. These internal problems need to be taken care of by a competent technician since the lens needs to be completely disassembled. I have also seen these shutters go bad and need to be replaced. Let's hope that's not the problem because it will be difficult to get a new shutter for the lens--but not imposible. God luck.
Apr 30, 2007 | Bronica SQ-Ai Medium Format Camera
General Electric E850 Digital Camera Logo
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
