Question about Kenwood Car Audio & Video
Red power light is on, on ps200t. is that normal
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Interior red light flashing when car locked?
normal...security warning light to deter theft.. uses very little power
Oct 02, 2012 | 2005 Peugeot 206 1.4
Installing fan & light control (27182) - in the box, there are red, white and black wires. On the control, there are red, blue and black. So, black to black; red to red; right?....does blue go to...
Under normal circumstances, NO! Black is normally power in to a box and to a switch. The switch controls the power out to the red line and most likely the blue line. White is always circuit neutral (ground). Your power will most likely come in via black and then go to the lights on either red or blue and to the fan on the other wire, either red or blue, the color you did NOT use for the lights. Some place you should also have a bare or green wire that would act as equipment ground, connecting to the metal of the box.
Sep 06, 2010 | Hunter Ceiling Fan Light Switch Control
Modem keeps blinking a red light then turns to a green and red light
If you are referring to power light, blinking light specially if red indicates hardware damage. powering down the modem for a minute and powering it back on normally stabilizes it but if not normally it needs replacement.
Mar 18, 2010 | 2wire (1000-000057-000) Modem
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
Inoperative LCD TV
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Jan 02, 2009 | Televison & Video
LG intello 7kg no power. no red light nothing
You need to check the main power cable and also check the power board.
Good Luck!!
Aug 29, 2008 | Washing Machines
Car Audio & Video Logo
32 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
