Question about Garden
How to change oil on a 11a-546b729 - Garden
How to change oil on 158cc briggs
remove oil check stick,Tilt it over and let it run out of the hole. New tech,lol.
Oct 26, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
How to change oil on mtd(11a-549r729)
i find the best way to change it is to run it out of gas then tip it on the side and drain it from the dip stick tube
Jul 27, 2012 | Garden
Briggs and stratton 6.5 started smoking so changed oil in hopes would help still smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Jun 01, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
What tool should i use to change the oil on a push Troy Bilt lawmmower Model 11A-439R766 XVS 6.5HP 190CC
The drain plug is made to fit the square end of a 3/8" wratchet extension.
Jun 14, 2010 | Garden
BOLENS, 4,5 HP Model # 90012 PN# 11a-084c163 SN: 10293-31672 We are looking for a manual to know what type/kind of oil and when to do the oil change. We would like to know if we should use only gasoline in...
use 30hd oil in the crankcase about 20 oz., change it about once a year. but check it every time you refuel.
it is a 4 cycle engine so it uses regular gasoline in the fuel tank.
good day.
Nov 18, 2009 | Garden
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Jun 06, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
