Question about Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830
Toro zx 4800 won't move - Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Posted on Apr 12, 2012
  • 6468 Answers
SOURCE: Toro Z5000 won't move
did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
Posted on Apr 15, 2012
  • 6468 Answers
SOURCE: proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Posted on Apr 21, 2012
  • 256 Answers
SOURCE: toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
Posted on May 17, 2012
  • 6468 Answers
SOURCE: Toro z master won't start
bypass the safety switches one at a time to test them
Posted on Sep 22, 2012
Toro zero turn 52" commercial won't move but I can
is that push it around in your shop?
Apr 11, 2013 | Garden
Wireless adapter for my gateway zx series won't come on
upgrade drivers, switch on wirless in BIOS, switch on wireless hard swith (or key combination - look to manual)
Nov 13, 2012 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Sep 19, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Toro turf sweeper 4800 HL won't fire, new coil part no. 166-0820 put on
Make sure you are getting power to the coil.
Apr 23, 2012 | Garden
Proline toro commercial 32 inch won't run
Apr 19, 2012 | Toro Garden
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Apr 13, 2012 | Toro 60'' Zero Turn Lawn Mower Enclosed...
Toro 52 inch walk behind blades won't engage
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830 Logo
63 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
