Question about XO Vision XD103 FM and MP3 Stereo Receiver with USB Port and SD Card
Usb connection failure on XD103
Everytime i plug in my iPhone 4 into the usb port, the phone charges yet the radio doesn't play the music and switches to the radio. When i try to switch to USB, there is an error that pops up that i think is 'USBER' before switching back to the radio.
  • dan metz
    dan metz Jul 23, 2013
    i'd love an answer to this, as i'm having the exact same problem!
  • mister magik Sep 18, 2013
    Just installed xd103 and same issue no idea what "USBER" is
Is there a way to play my IPhone music on Hyundai Accent 2005 Stereo? It's annoying that I have to use a CD.
Play music through USB in the car - Windows Central Forums
forums.windowscentral.com/.../209188-play-music-through-usb-car.htm...
Dec 19, 2012 - 25 posts - ‎18 authors I own a Hyundai Sonata 2012 which has a USB port that worked perfectly for listening to music on my iPhone. ... and it SUCKS. i want to be able to charge my phone via USB while I listen to music. .... I even bought an ALPINE stereo head unit and tried that, as they supposedly work with NOKIA phones, but.
Oct 21, 2015 | Hyundai Cars & Trucks
XO Vision XD 103 USB Troubleshooting
the answer is the AUX port. get a cord that plugs into your iphone's headphone jack and has the same plug on the other end to plug into the XO Vision's AUX port.
Jul 20, 2013 | XO Vision XD103 FM and MP3 Stereo Receiver...
Installing an XO Vision XD103 to a 2001 Ford Ranger
Easist way to install it is to get a dash kit,End a wireing harness adapter kit that plugs into the factory radio harness,
Dec 06, 2012 | XO Vision Xd103 FM and MP3 Stereo Receiver...
Iphone will not charge..... message says charging is not supported with this accessory.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 21, 2012 | Apple iPhone4 4G iPhone 4
Why is my iPhone 3GS not charging?
First Option:
Second Option:
Aug 09, 2012 | Apple iPhone 3G
How do I pair a RocketScience Tracer bluetooth?
    • 1How to Pair a Bluetooth Device With an iPhone On the iPhone, click on the "Settings" icon. It looks like a gear. Then press on the "General" button. Select "Bluetooth" and then "Turn Bluetooth On." The phone is now ready to be connected to the Bluetooth device.
    • 2 Connect the iPhone Bluetooth travel cable that comes with the iPhone-approved Bluetooth device into the USB 2.0 port on the computer. Do not plug it into the USB port on the keyboard.
    • 3 Connect the iPhone to the other end of the cable. The cable goes into the data connection slot on the bottom of the iPhone. There is another slot on the top of the cable into which the Bluetooth device should be plugged in.
    • 4 Wait while the computer loads to recognize there is something plugged into it. Either a screen will pop up or an icon will appear on the desktop to let you know that the computer is recognizing there is a iPhone plugged into it.
    • 5 Let the Bluetooth device charge with the iPhone for about one hour. You can tell when the device is fully charged by viewing the status light on the device. It will be an amber color until it charges completely. Once the charge completes, it will turn green.
    • 6 Remove the Bluetooth device and the iPhone from the cable that is plugged into the computer's USB port. Push the button on the top of the Bluetooth device. This allows the calls to now go through the Bluetooth device instead of straight to the iPhone.
Jan 02, 2012 | Apple iPhone 3G
I dropped my iphone and it said no sim, i put it back in but now the home button doesn't work and it won't charge a and my computer is not registering it when I plug it into the usb port, is there...
Hi
its seems like you have loose connection inside of phone. because home button and charger port have same pin connection.
My advice is you have to take your phone to technician.
thank you.
Sep 07, 2011 | Apple iPhone Smartphone
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
XO Vision XD103 FM and MP3 Stereo Receiver with USB Port and SD Card Logo
107 people viewed this question
Top XO Vision Audio Players & Recorders Experts
Gyula Lacz
Belzonsci Belzonsci
Belzonsci Belzonsci
Level 1 Expert
Are you a XO Vision Audio Player and Recorder Expert? Answer questions, earn points and help others
