Question about Cub Cadet Garden
Bypass seat switch on LTX 1042 KW
I'm used to seeing 2 wire plugs this one has 5
emissionwiz
  • 76164 Answers
SOURCE: electric seat motor switch...no move back
the problem is the switch, replace it.
Posted on Apr 21, 2009
SOURCE: Need to know where the wires connect to and from
libia
Posted on Jun 08, 2009
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
  • 4862 Answers
SOURCE: How do I bypass the parking brake wire ?
This is illegal and if stopped by the police , you will be prosecuted
Posted on Mar 21, 2010
SOURCE: can you use Fix a flat to repair a flat tire on
remove rear wheel to fix flat tire
Posted on Aug 10, 2010
LTX 1042 KW wont start. I was running my mower, had to stop for a moment, now it will not start. It won't even try to turn over
Make sure blade is engaged and you are seated firmly on seat. If so either your blade or seat safety switch is bad. Also your brake pedal bas to be completely engaged.
Aug 03, 2017 | Garden
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Changing Spark plug, manual doesn't give sparkplug gap setting
Hi Joseph, The link below is a short YouTube video, This guy shows the right colour spark and I never thought about it but it should spark over the top of the centre electrode, Hope this is helpful.. CHEERS...
https://www.youtube.com/watch?v=mUOmsGiirTU
Mar 24, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
After start engaging blades engine stops
Most likely a safety swich not working.....alot of times its the one under the seat,.
Aug 03, 2015 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Cub cadet lt1042 will not back up a small hill
When is the last time you changed out your drive belt?
Oct 02, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Ltx 1042
Sounds like drive belt is broken. How old is tractor? When is last time drive belt was changed?
Jul 20, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Where is the fuse
behind the dash panel at top of dash there is only one fuse
Mar 19, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Will not start
Follow red wire to soleneid , then follow small red wire to in-line fuse holder.
Jan 04, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Change fuse
Follow red battery cable to solenoid, then follow small red wire to in-line fuse holder. Remove fuse and replace same amp fuse.
Garden Logo
93 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
