Question about Toshiba Satellite A100-S8111TD Notebook
Bluetooth not working
When i put attached the dongle, COmputer says thank you for evaluating the bluetooth stack for windows by toshiba, The evaluation period has expired. Please obtain a license for this version of bluetooth stack for windos by toshiba
I need driver for Bluetooth USB 2.0 Dongle for window7 and toshiba bluetooth usb
Hi rhegem09,
You can download the Bluetooth Stack for Windows 7 by Toshiba (32/64) from the below link.
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_bluetooth_TC00241200A.exe
Please download and install it in the Computer. After that restart the Computer for the settings to take the effect.
This should fix the issue.
Hope this helps.
Good Luck!
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 24, 2010 | Toshiba Satellite A215-S7422 Notebook
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
Sep 06, 2010 | Sennheiser BW900 Bluetooth Headset
Can i hook my emerson bluetooth up to my computer
Yes, IF your computer has Bluetooth software and either a built-in Bluetooth radio or a USB Bluetooth dongle.
If you are running Microsoft Windows, then you have the Bluetooth Stack (software) and just need a radio and driver or a Microsoft USB dongle to activate the stack.
Apr 23, 2010 | Southern Telecom Emerson Bluetooth Headset...
Bluetooth capable, but need license??? from toshiba
BlueSoleil is a freeware Bluetooth Stack you can use instead of paying for Toshiba's version.
http://download.cnet.com/BlueSoleil/3000-18511_4-10972014.html?tag=mncol
Did this resolve your issue? If so, please rate this. Positive comments always appreciated too! ty.
Feb 26, 2010 | Computers & Internet
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
Satellite a135-s4527 windows xp bt stack expiring
u can find here what u want
http://aps2.toshiba-tro.de/bluetooth/?page=download
Aug 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Need à passkey to browse my USB Bluetooth Dongle
the out of the box passkey for most bluetooth devices is usually 0000
The passkey has to be entered on both devices so they can pair.
Aug 04, 2009 | Acer Computers & Internet
BLUETOOTH ACTIVATION
You should try and download the software from the manufacturer's internet site, from which you bought the bluetooth dongle.
Toshiba manager and stack is only for built in solutions from Toshiba.
But haven't you got any CD or DVD with your dongle? Normally it is bundled with the device so that you can use it too.
R
The Toshiba Bluetooth stack on the Toshiba website is customized and designed for Toshiba notebooks.
You should use the Bluetooth stack which is customized for your notebook. Then you would not need to activate any BT.
But listen dude; your Satellite P200- 1C7 seems to be NOT equipped with the Toshiba internal BT module!
Therefore you would need to switch to another external solution
Dec 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A200 - Bluetooth
Hi i have the same problem and no 1 could help me too. i ended up buying a bluetooth dongle from argos £6.99 it does the same job . just means you hav a dongle instead of the built in one . if you get help give us a shout mycarford@hotmail.co.uk
Oct 04, 2008 | Toshiba Satellite A100-S8111TD Notebook
How to open my bluetooth? Toshiba laptop
i believe your computer doesn't have a bluetooth device installed. but i think the laptop is bluetooth ready which means that there is bluetooth stack software in the computer. all you need to do is purchase a usb bluetooth dongle and install the software that came in with that device.
i hope this info helps you.
Sep 03, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
305 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
