Question about Kenmore 33721 Upright Vacuum
Change belt on sears upright vacumn 116.34613305
How to replace the belt on bissell healthy home vacumn
I think this is a terrible answer.. but after researching everywhere on how to change the belt, most answers were to look up the owners manual. So I looked it up online. this is all it has on changing the belt:
"Belt maintenance
The brush belt is designed to last the useful life of the cleaner when used according to all
instructions in the user guide under normal household conditions. If you feel that it needs to
be checked or replaced, call BISSELL Consumer Services or visit the website to locate an authorized service center. Do not attempt to disassemble the vacuum foot to change the belt."
Frustrating! Good luck!
Jun 07, 2011 | Bissell 5770 Healthy Home Bagless Upright...
My vacumn wont pick anything up and it wont self propel. I checked the belt - it is fine.
There are numerous things to check.
  1. Check for hose clog
  2. Brush belt has many hairs and doesn't move
  3. Brush belt broken/loose
  4. Vaccum bag is full
  5. Height adjustment according to floor.
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I change the belt on my vacumn
there should be some screws on the bottom of the machine. take out the screws and remove the cover
Apr 18, 2009 | Bissell 6594 PowerForce Bagless Upright...
My vacumn wont pick up from the bottom but the hose works fine. I emptied the bag and the green light is on.
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
How do I get inside to replace u belt ?
Remove the three philips screws holding the yellow cover on the base. It will lift off, exposing the roller bar and belt. There are further instructions for belt change on a label inside.
Sep 04, 2008 | Vacuums
Non spinning brush
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632342
Generic problem for all Vacuums
Non spinning brush
Posted by tillie14 on May 29, 2008
I have a Kenmore upright beltless that suddenly, the brush stopped spinning. Do you have an answer for this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Kenmore upright the belt is broken and needs replacing and you can take it to Sears / Kenmore or a local vac dealer and they can change it for you or you can attempt to do it yourself, usually it just takes a screwdriver and either a flat or a geared belt for less than $10.00 to $15.00 is an estimate.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
No vacumn action
Is the roller turning, if not you may need a new belt and/or brush roll. Did you check the inlet by the brush roll?
Feb 09, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Kenmore 33721 Upright Vacuum Logo
53 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
