Question about Garden
Tempo riding lawn mower
Need steering parts
SOURCE: Lawn mower
Definitely do Not use these oils in your engine! Any good motor oil of the right viscosity will work, such as 10/30 or 10/40.
Posted on Sep 10, 2008
  • 708 Answers
SOURCE: RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Posted on Mar 28, 2009
SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
Posted on May 01, 2009
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 636 Answers
SOURCE: MANUAL FOR A TROY BUILT RIDING LAWN MOWER
Try this site it is called manuals online . Should find what your looking for , Free.
Posted on Jul 24, 2009
I have a craftsman revolution riding mower and its having troubles turning to the left. model 247.28933 any ideas??
Check the steering rack cogs r
Are not missing each other as you turn the wheels left if the teeth gap increases as the wheels turn the rack is worn and will need adjusting so the teeth meat better or the rack will need to be replaced this . Part can be quite expensive I had a countax ride on same problem would not turn to the left easily or the steering wheel would just spin. Around but the front wheels did not move until you pushed them by hand 're engaging the cogs on the rack it was nearly £ 596+ vat just the parts needed to repair it
Jun 26, 2016 | Craftsman Revolution 42" Briggs Stratton...
Front end out of alignment how do i fix
Paul it appears your machines steering components are not adjustable, as normal tie rods are. So that means you have to replace steering parts that are worn or try and repair bent steering parts. You could have your steering links made adjustable at a machine shop. below is your manual,
press the helpful button.
http://www.homedepot.com/catalog/pdfimages/fd/fd904936-46bd-471e-9536-7c3ca3698e81.pdf
Jan 30, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Jul 17, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Steering wheel is hard to turn on cub cadet riding lawn mower seems locked up
Start buy checking from steering wheel down the shaft , to gear that does turning, to shaft underneath mower that goes to steering tierods , to tires. Oil and grease will do wonders on any parts that look rusty, or may be tight. Definately check air preasure in your tires. You should be fine.
GOOD LUCK.
Jun 16, 2011 | Cub Cadet Garden
I have a 2 year old Cub Cadet and I find it very hard to steer the wheels during mowing.
First grease the the axles and all steering components associated with steering, there should be grease fittings where you can pump grease into, then make sure your tires are all filled to proper psi. Good Luck...
May 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My steering wheel is really sloppy on my craftsman lawn mower
Try this: Kit.steer.as PART NUMBER: 149686 Substitution: 167902
enter either of those numbers into your browser and find your best deal. I got mine from outdoor distributors, they had the best price. This is the whole assy, the individual parts add up to a lot more.
Mar 17, 2009 | Garden
Front wheels of our riding lawn mower
Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
Sep 18, 2008 | Garden
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
