Question about Navigon 2090S Car GPS Receiver
Failed to get path to mobile navigator - Navigon 2090S Car GPS Receiver
How to downlpoad navigation path
really need your question to have more info.about what your trying to do. if you put in your home address and then go to navigate and type in your destination as it ask you to do, then the gps will automatically navigate you to that destination.
Jan 03, 2015 | GPS
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
Navigation system turns off and reboots itself every 4 minutes (timed)
Navigation is hard, isn't it? In Settings where to set the navigation path, before is ok,electrical tester
Apr 01, 2013 | 2010 Porsche Cayenne
When I pull up the gps for directions it says it cannot find program. Please set Gps path in file. What do I do to fix it.
Set GPS Path ..
On your Sylvania GPS go to System Setting > GPS Path .This function is to set GPS path for your navigation. Screen display will show asfollows:
File folders of TF card will be listed on screen. Click a folder to open it. Select GPSSoftware If there are two or more maps from different companies on an TF card, then thisfeature can help you select each of them easily. The way to Select: :In TF card directory,open the file folder to find the map to be used, select navigation software of .exe,(whichhas different names from each different company), then select andclicK 10_3_2011_2_45_46_am.gif icon, a dialogue frame will pop up on screen, as it shown below:
Click the accept icon to accept.
Click X icon on the upper right corner to return to GPS path interface.
Oct 03, 2011 | Sylvania SGPD430 GPS Navigator
By pressing Navigation I am ask Please set Navigation Path.I have not idea what to do next.
On my GPS, I scrolled down to and pressed Navi Path, then turned on "Auto run GPS when starting", then set the Navigation Path to Resident\.........\iGO8. It then worked ok.
Aug 11, 2011 | GPS
Ihave forgotten my password of memorycard of nokia n72 so please tell me how to unlock the memory card.
Hello and Welcome to FixYa!
It is easy, first download and install a program named Fexplorer in your mobile, you can find it here
Then Follow the steps, its easy as 123;
  • Insert the card in your mobile, don't access it.
  • Run Fexplorer
  • Open the path C:\system (First goto C: then navigate to a folder named system)
  • You will find a file named mmcstore rename it to mmcstore.txt
  • Copy that file mmcstore.txt to your pc and open it.
  • You will find the password written in it.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Dec 13, 2010 | Cell Phones
My Evesham nav-cam 7000 model ps1025 is showing
My Evesham nav-cam 7000 model ps1025 is showing the following:-fatal application error Application Mobile Navigator.exe has performed an illegal operation and will shut down.If the problem persists contact the program vendor.Program 0xc0000005 Address 000d026c.What can i do to remedy and get a cd disc for it?
Oct 12, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Message sending failure
Go into:
-meassages/message settings/common settings or anything similar to this that contains the command "reply path"
-activate reply path to yes.
try this,hope this helps
May 01, 2009 | Cell Phones
My navlink gps says "not find navigation software"
If you haven't already fixed this; try going into, settings, navsetup, - this should give a Path of navigation software line, this line should read: '\StorageCard\iGO8\iGO8.exe' click on file icon at end of the path window "select storage card, select iGO8.exe, select tick to apply then exit.
This works for mine but I assume that if an alternative software is shown in the path window you must choose an approppriate .exe file in the storage card files.
Oct 28, 2008 | GPS
Open Questions:
I cannot start my NAVIGON GPS 3310 - Europe 40 pays: I get a message that tells." NAVIGON software cannot be started. Please reset you device. Contact the Navigon Service center if the problem persists: The problem does persists in spite of the numerous reset I did. I also tried to restore the factory settings, it does not change anything. When I connect the GPS to establish a conection between the GPS and the computer, for example save the content of the GPS in the computer I get a message which tells me No device was detected (CG2001) No Navigon device was detected. They suggest to unplug and plug again the GPS to the computer, I did so and get the little music which tells me that I am plugging/unplugging a USB device, and I see NAVIGON in Windows Explorer. But still I get the same message that No device was detected: Ths GPS was delivered with all data in the internal memory and none on the SD card (It was working with no SD card). It seems to me that all data in the GPS disapeared, and unfortunately I did not save the data when I I had a chance. Do you think you can help me? I was thinking that perhaps I could install a SD card will all data, meaning Navigon program and maps, and may be it would work. What do you think about that? The problem would be to find this data, The Navigon progam in particular. As for the maps they can be bought, but on a DVD as far as I know, and what if the computer does not recognise the GPS? So, as you see I am puzzeld and seriously consideing buyin a Garmin instead,. I,ve heard that they are more reliable.
Feb 28, 2017 | Navigon 2090S Car GPS Receiver
Navigon 2090S Car GPS Receiver Logo
106 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
