Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included Logo
A
Anonymous Posted on Apr 20, 2013
Squeaky tire my back tire is really squeaky and what to use to stop the noise
My 2000 ford mustang gt v8 make a sweeky noise in the rear tires after even after changing rear brakes and shocks.
The squeaky noise can be several things, but usually it's how your pad contacts the rotor provided it's rear disc. Check the caliper slides, if it's not sliding back and forth, you'll wear the inboard side pad and it will squeak.
I have a 1999 Ford Explorer XLT, awd 4x4 4.0 liter v6 sohc and the front passenger side tire is vibrating pretty bad and would like to know thebest place or places to start ?
the awd models have a habbit of ball joint and bearing problems with the front end...350.00 each side minimum to replace...
1helpful
Front Left side wobbly and there is a squeeky noise when driving
Have you checked the tires ?
Sometimes a wobble can be a broken belt inside the tire tread.
Or it could be something loose in the hub.
You could also switch the front and rear tire to see if the wobble moves.
Have a noise coming from the back wheel area. Gets worse as you apply the brakes and almost sounds like it needs new pads or have the rotors turned. But I have had it in 3 times and dealer turned the...
There is a product sold by autozone.com called 'DE-SQUEAK' by CRC chemicals that sprays on the brake rotors with the caliper off, and when dry will reduce the squeaky noise of applying brakes.
What does your noise sound like?
Are the tires the right size for the car?
Loud squeaky noise from front tires when turning and somtimes whe
Hi my name is Tom and I can help you.
Driving with your emergency brake on is only going to affect your rear brakes. There is a cable running from the emergency brake lever to your rear brakes.
You did not say how long you drove with the emergency brake on, but even a short distance and you forced the front brakes to do the work of stopping the car. This causes overuse which translates to heat. When the brakes over heat they "fade" and do not stop the car effectively.
In addition the heavy load of doing all the stopping causes the brakes not to realign. Therefore, when you go around corners the brakes pads will rub against the rotors.
I would suggest you get the brakes looked at or look at them yourself. I can help you do the job but I would need to talk to you directly. Let me know what I can do to help.
TomE
1helpful
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Noisy rear wheel
Your wheels are probably rubbing against your brake caliper, or the dust shield.
2helpful
2answers
Dry squeaky grinding noise 2003 explorer
That's where I'd go first. check with driveline unloaded (neutral with wheels off the ground.)
Squeaky Rear suspension
I had the same problem. I had the control arms repaced in the back when my car was still under warranty. See if a mechanic can take a look at it to be sure.
Top Quickie Wheelchairs Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Quickie Wheelchairs Furniture Expert? Answer questions, earn points and help others
