Question about Prima C2012 TV
I need a code for my prima lc32u16. 30inch tv in order to program it into my bell satellite remote
We need a code for prima tv to program it into our bell satellite remote?
SOURCE: PRIMA TV CODES
The 4-digit RCA code is 1238 if using an older RCA universal remote, or just 238 for the newer 3-digit ones.
Posted on Sep 28, 2008
  • 65 Answers
SOURCE: universal remote prima tv code
Codes are 0062,0039,0294,0442,1299,1537. Ted10
Posted on Apr 16, 2009
SOURCE: I am having problems programing a universal remote
urc-386-remote.blogspot com
URC-386 HRS-GLOBAL
URC-386 Universal Remote Control
http://urc-386-remote.blogspot.com
Posted on Feb 03, 2010
SOURCE: remote control code
Prima 4101 4138, 030,032,036,039,047,054,056,060,091,016,415
466,092,166,251,017,281
BIG SCREEN=166,019,035,154,451,037,068
Posted on Feb 24, 2010
gopakumarg43
  • 74136 Answers
SOURCE: need code for Prima tv remote
Hello
Four digit universal remote code for Prima are:-
1019 0165 0116 0167
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Posted on Dec 03, 2010
I have RCA RLDED5099 Tv, but can't program it to work with my Bell satellite remote so I can then work My JVC THA35 home theatre..
Bell Satellite remote codes for RCA TVs: : 001,005,006,008,012,014,015,018,023,
025,035,066,077,085,121,124,131,133,135,
144,148,150,151,152,155,160,167,190,194,
222,223,225,227,232,236,245,248,268,269,
282,288,289,317,431,486, 492
Instructions for when the code for your device is not listed. Use this procedure to scan the remote control’s memory for the device code
1. Turn the device on (TV).
2. Press and hold the mode button until all the other mode buttons light up, and then let go of the button. The mode button flashes.
3. Press POWER.
4. Press the UP or DOWN ARROW repeatedly until the device turns off.
5. Press POUND (#).
6 .Turn the device back on and try some other buttons to make sure they work
7. If necessary, repeat this procedure
How to program my Bell Satellite TV remote control
Apr 09, 2015 | RCA Televison & Video
I need a code for a Prima Q328 Television
It may not be possible as that remote has a limited number of codes and even if it programs may only do a few things.
Try all the possible codes and look to see if that remote has a search feature which would allow you to try each and every code it has.
Nov 07, 2012 | Televison & Video
I'm looking for the remote code for the PRIMA LC-20Y15 television in order to activate my remote control for my Bell Satellite system. Any ideas? Thanks
The remote codes are here.
I didnt see the Prima LC, but you can still problem with the instructions below.
If you tried all the codes provided for the manufacturer, try the following steps to find another code.
  1. Make sure the TV is on.
  2. Press and hold the TV button on the remote until the SAT, TV and VCR buttons light up.
  3. Let go of the TV button. The TV button should start to flash.
  4. Press the Power button on the remote control. The TV button will stay lit.
  5. Press the up arrow on the remote every second until the TV turns off.
  6. When the TV turns off, press the # button on the remote to lock the code. If the scan was successful, the TV light will flash 3 times.
Your remote should now be programmed to work with your TV.
Dec 21, 2010 | Televison & Video
Program bell remote to emerson tv What codes do I use to program my bell satellite remote to be able to tun off/on tv and to use the volume from one remote
Hi try this
Emerson 526, 534, 536, 541, 573, 590,
627, 636, 642, 648, 652, 654,
655, 657, 658, 659, 660, 661,
662, 665, 666, 667, 669, 670,
677, 679, 682, 692, 696, 699,
720
http://www.bell.ca/web/tv/en/all_regions/pdfs/deviceCodes.pdf
good luck please rate
Dec 18, 2009 | Bell Televison & Video
I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Dec 16, 2009 | Prima C2012 TV
The code to program my remote control for my tv Prima PH 42R6C''
I need to know the code to program a new universal remote tv for my PRIMA PH-42R6C. I don't find the code and i don't know what kinf remote i need for this tv.
The problem is i lose the remote
Thank's for your help
yvon.rathe@sympatico.ca
Mar 03, 2009 | Televison & Video
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
I have an RCA universal remote and I need a code for a Bell ExpressVu satellite in order to use the remote for both my TV and Satellite.
004 was the only code I could find for Bell but i do not think it will work. Therefore, i recommend the following:
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 26, 2008 | Televison & Video
Can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
Mar 30, 2008 | Televison & Video
Prima C2012 TV Logo
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
