Question about Compaq Pesario S4120WM (DK216AR#ABA) PC Desktop
My computer fan is running continuously, from the time it turns on. (even before booting in to windows xp) why does my hard drive fan kicks in all the time - its loud and annoying
  • Anonymous Apr 15, 2009
    I just got my tower back from being repaired. The mother board had died and had been replaced with a few other parts. Since I have gotten it back the fan runs continueously and I noticed some changes in my accounts.
    Scholar:
  • 26 Answers
Hi burroughs,
Unfortunately modern processors inside our computers today run extremely high temperatures do to the non-stop demand that is placed on them by games, operating systems such as windows, and kernel operations being performed non-stop in the background.
If the noise is bothersome to you, what I would recommend doing is buying new smart fans from your local computer store for your CPU.  They will automatically adjust how fast they need to run depending on how active your computer is.
That or you could look at investing in a liquid cooling system, but this is a very expensive solution.
Hope this helps, and dont forget to vote/rate!
Posted on Mar 12, 2009
  • 252 Answers
The fans in most desktops do run whenever the unit is on. Only high end/ performance/ or self built systems usually have self adjustable fan speeds.
I've installed windows xp SP2. 1st windows was succesfully formated and copying windows, then windows booting, and this massage appear "Press any key to boot from CD/DVD"... then i let it...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jun 03, 2011 | MSI PM8M-V Motherboard
Tip
How to repair Windows XP Master Boot Record (MBR) From time to time you will...
From time to time you will need a message on your computer when boot that states that your Operating System was not detected or that your primary hard drive was not found. When these messages come up alot of people think that there hard drive had fail. However alot of times it is just because the Master Boot Record on the hard drive got corrpted so the data on the drive can not be read properly. This also is the cause of the flash cursor that people will see from time to time.
Note in these cases you will always want to run a hard drive test before the reinstall of Windows as a drive failure could have caused the problem but run through the below step will alot of times show that the drive is fine.
The steps below will take you repairing the MBR on your har drive. Note to go through this process you will need your Windows XP OS CD.
1. The first thing you will need to do is boot your computer off your Windows XP OS CD. To do this you will need to go into your BIOS and change the boot order to have your ROM drive set as the first boot device. Note some OEM computers have a boot menu set to a hot key like F12. This option sould let you boot from the ROM drive without having to go into the BIOS.
2. After you have selected to boot you computer from the ROM drive with the Windows XP OS CD in the drive you will seee a message that states "press any key". You will need to press any key on your keyboard to have the computer boot off the Window XP OS CD.
3. After the setup loads you will want to select "R" to run the Windows XP Recovery Console
4. After the Windows Recovery Console loads you willl need to type the number that refers to the drive that you are wanting to repair. Note in most cases you will type "1" then press enter. Then you need to enter the Administrator password for the system. If you do not know it or does not work then at this point you will need to look at backing up for files with another computer and doing a full reinstall of Windows on the hard drive.
5. After you are able to enter the Administrator password you will be at a prompt here is where you will type "fixmbr". This will repair the damaged MBR. Inaddition will may want to run "fix boot" this will fix any issues with the boot sector.
Note if you still have trouble getting the system to boot properly after running through these steps you will want to do a backup of your files and do a full reinstall of Windows. Also run any hard drive tests to make sure there is not anything wrong with the hard drive.
on Dec 06, 2010 | Computers & Internet
Does not boot OS. Hangs when trying to load and chose option to run windows in safe mode, computer restets. Have had previous issues last few months with turning on PC and fans kick in, ect, but not...
Test all leads that attach to your hard drive including IDE,SATA and electrical extensions also from your motherboard to your hard drive or just replace them also make sure that all cd,dvd,
3.1/2floppy drives connections are secure and not faulty then uninstall programs you do not need or use then run chksdk/f then defragent your hard drive
Aug 16, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
How to set up dual boot for two hard drives?
My freind, you can boot from two hdd inside the same computer. You can only boot from the primary HDD. What you need to do is install both Windows 7 and XP on the primary hdd in different partitions. Then when you boot the system it will give you the option for booting to both XP and 7. You dont even need the secondary hdd unless you are looking to have more storage space.
May 04, 2010 | Computers & Internet
XP rebooting again and again
Do you now have both hard drives plugged in? You must have the Master hard drive in the IDE1 slot and the second hard drive jumpered to cable select and put on the IDE2 slot. As you are looking at the cable from the open side of the computer, the IDE cable connected to the hard drive should have the red stripe towards you. The end of the ribbon cable should be plugged into the primary hard drive, with the second hard drive plugged into the second plug on the ribbon cable. On the hard drive there should be a diagram for how to jumper each hard drive for primary or cable select.
NOTE: You cannot put a hard drive into the computer and expect it to boot, even if it has an operating system on it. The OS must be installed onto the hard drive after being installed into the system.
Good Luck,
NOLA Tech
Jan 31, 2010 | Compaq Presario 5000 PC Desktop
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
1. Boot the computer using the XP CD. You may need to change the boot order in the
system BIOS so the CD boots before the hard drive. Check your system documentation
for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery
Console, press R", (you Do Not want to load Recovery Console). I
repeat, do not choose "To repair a Windows XP installation using the
Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows
installations.
5. Select the XP installation you want to repair from the list and press R to start the
repair. If Repair is not one of the options, END setup. After the reboot read
Warning
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any
key to boot from CD when the message appears. Setup will continue as if it
were doing a clean install, but your applications and settings will remain intact.
Apr 05, 2009 | Computers & Internet
My Dell Inspiron 700 laptop with Windows XP suddenly will not boo
Remove the hard drive, then see if you can boot to the XP CD. If you can, then the Hard DIsk Drive has most likely failed. Reseat the HDD and try booting to CD again. If problem comes back, try a new hard drive.
Mar 31, 2009 | Dell Inspiron 700M Notebook
Computer won't wake up
ok, there could have been a graphics issue in the bios caused by the windows graphics drivers, heres what you could try........... remove the power cord from the back of the machine, remove the side panel to allow access to the motherboard, you will see a battery! take it out for 10 mins and push the on/off button a couple of times, this will drain any remaing power from the motherboard, after 10 mins the CMOS should have cleared so you can replace the battery, plug in the power and turn the machine on hopefully you'll get a signal
good luck
Nov 17, 2008 | Computers & Internet
Drive Not Ready
typical of external drives overheating.
i sell external case with fan at my store.
Nov 03, 2007 | Fantom Titanium Hard Drive
Compaq Pesario S4120WM (DK216AR#ABA) PC Desktop Logo
241 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
