Question about Tools & Hardware - Others
I need the height adjusting knob for a 3612 BR router
  • 10,865 Answers
Http://makita.com/en-us/Modules/Service/ServiceCenters.aspx
Go to this site and order the part.
please mark this as a fixya. thanks
Posted on Mar 12, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
How do I adjust the height of the drafting table?
You should loosen the knobs, adjust the height and then tighten the knobs once you are happy with the height. Screw it tightly and lock them in place.
Jan 07, 2013 | Furniture
How do I adjust the leg height of my drafting table?
There should be screws/knobs at the table base. I've also seen these at the front legs of the table. You have to loosen the knobs, adjust the height and then tighten the knobs once you are happy with the height.
My mower deck will not hold adjustment
I had the same problem. I fixed it by wrapping one end of a bunge cord around the adjustment knob and the other end to the tractor frame. The pressure from the bunge cord holds the knob against the height adjustment slots. Give it a try.
Aug 22, 2012 | John Deere Garden
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
I need help on how to replace bit on router craftsman style
You didn't state the model number. The older Craftsmen routers had a red lever lock on the top of the router, one position allows the spindle to turn, the other position locks the spindle. Here's the instruction for the older style routers:
  1. Unplug the tool.
  2. To lock the spindle press the red button in and slide it to the locked position.
  3. Unlock the height adjustment knob.
  4. Raise the router motor using the height adjustment collar until you can get a wrench onto the collet nut.
  5. Loosen the nut until it turns freely.
  6. The bit may still be locked in the spindle, tap it gently (not on the blade!).
  7. The bit will come loose in the spindle and can be removed.
  8. Replace the bit, tighten the nut snug but don't use excessive force.
  9. Unlock the spindle, returning the red lever/button to the free position.
  10. Adjust the height of the bit as you wish, then lock down the motor using the locking knob.
Mar 19, 2009 | Craftsman Tools & Hardware - Others
How to adjust the collet easily?
Look for a button that will lock the collet in place. This will allow you to adjust the collet with a single wrench, without having to wrestle with several wrenches.
Aug 27, 2008 | Porter Cable 75300 Height Adjustment Knob...
Tools & Hardware - Others Logo
122 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
