Question about Logitech QuickCam Communicate STX Webcam
My web cam wont present video after instalation what should i do. It presents audio but not video
  • 43 Answers
Replace the driver. Also check your web cam if it is working. If not better to buy new web cam.
Posted on Mar 12, 2009
Video recording on my laptop
Cause you did not specified your problem exactly ..I will refer about video capturing in general using the web camera and a laptop ..No matter if the camera is built in or external the procedure is the same...Open the AMcap..program in start menu / all program s..This is the program usually present when you install a web cam driver..and when you open it the camera will open a window for capturing ..If it shows nothing use the setings to enable video and audio and also the preview... This will make you an idea about the quality ..After that all you have to do is open the capture using the start capture function in options or so ..and stop them ...when you stop ..usually it asks to save the file in a location ...You may also be asked when you start to assign a size for the file ..
There is a better way to make a capture and this is using a capture program ..and I will recommend the windows movie maker...Itis present in all windows..and has a capture from device feature..and you have the editor advantage with i t..and the fact that will capture from other devices than web cam alone .too..so you can increase the quality as well ..
Please ask if you have any future question s..
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Aug 25, 2011 | Compaq Presario CQ50-215NR Notebook
Hello i have a problem with my cyberlink you cam.i can not open it.it tells me that web cam can not open and i have to try another usb cam or turn of other application that may use this cam.i try many...
Goto RUN-> msconfig-> startup tab-> diasble all except antivirus. restart.
run-> devmgmt.msc -> check any yellow marks or explanation marks or red x present after inserting the webcam.. if it is update the drivers.
Please download the file amcap920.zip from http://www.download25.com/install/amcap.html and
install the setup.exe. It will create "amcap" in programs. click the amcap. you can see the
video from cam.
Hope this helps to you.
If your problem not solved, please let me know...
Jun 18, 2011 | Computers & Internet
Web came show but black screen no image showing on screen
Please adjust the zoom by installing webcam application.
Check any dust is present on the webcam.
Try this also
Please download the file amcap920.zip from http://www.download25.com/install/amcap.html and install the setup.exe. It will create "amcap" in programs. click the amcap. you can see the video from cam. '
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 10, 2011 | Computers & Internet
I cannot start web cam in my laptop. and its also not seen in program menu. kindly help
when you double click on MY computer you can see the drives and also your web cam as usb video device if it is not there then click on start on task bar select control pannel-->select add or remove programs wait until window shows its components check there ,wether the web cam driver is present in the list or not.if it is not in the list then instal the webcam driver and youcan see the usb video device in my computer
plese give votings and suggestions to improve my skills
Feb 16, 2011 | Computers & Internet
I want down load my genius m/n look 110 web cam drivers
All the drivers for Genius Web Cam are present at the bottom of the page of the link given below :-
http://www.1-drivers.com/webcams/genius.html
Look for the one you have and click and install it.
Nov 09, 2010 | Genius Look 110 Webcam
My laptop webcam wont work with skype
Try to uninstall any other video software that might conflict with the driver of your Microsoft LifeCam
Mar 28, 2010 | Microsoft LifeCam VX-3000 Web Camera
My web cam on my acer aspire 5534 does not work
Dear friend please follow the instruction.
1. Open My Computer then Double click USB Video
Device. If its not present there then you need to
install the device again OR If that present there but
not working then uninstall the device, restart your
laptop & follow the below instruction.
2. Installation Process. On your laptop. Put the Acer
Driver DVD on the DVD player. Select Web Camera
& run the set up as per your operating system.
3. After a while a popup message will show your that
Your web camera are ready to use.
4. Restart your laptop and Use it.
After all of these if your webcam not working then make sure your self that some how the camera damaged/disconnect from inside. Visit service center or ask me how to remove the cam.
Thanks & waiting for your reply.
Feb 08, 2010 | Acer Aspire 5610-4648 Notebook
Panasonic SDR-H18 Camcorder I get no audio
I found, from the Best Buy Geek Squad, that all Hard Drive Video cams use a audio format that only works with their hardware. If you burn a DVD (using their software) is audio will be present.
Jan 12, 2010 | Panasonic Palmcorder SDR-H18 Camcorder
Web Cam wont load
Uninstall the software for this webcam and then first install the software before connecting to the pc and then try connecting. Also install in a different location.
Thankyou
Jul 31, 2009 | Logitech Webcam
Head Gear WC755IPT Web Cam
I have a suggestion.. pls install SP2 of windows xp and try again..ok
Jan 04, 2008 | Microsoft Windows XP Home Edition
Logitech QuickCam Communicate STX Webcam Logo
66 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
