Question about Toro 50'' Zero Turn Lawn Mower Trailer Package Deal ()
Toto spindle bearing replacement
Need help in replacement of spindle bearings
2003 maxima rear spindle
The rear wheel bearing assembly/spindle CAN be replaced as a bolt-on unit. You should not need to replace the beam assembly. Unless the spindle is damaged or bent it should be okay as well. I will tell you from experience that you should buy top-quality bearings as most 1-year warranted auto part store units fail prematurely. Additionally, precise torque specifications for the spindle bolt is critical to bearing life. You cannot grunt-torque them and expect them to last. Use a calibrated torque wrench at the proper torque. I personally recommend Timken bearings. Just a suggestion.
Aug 24, 2014 | Cars & Trucks
Rear wheel bearing still grinding after spindle shaft and wheels bearings were replaced
you could have a new defective part is what it sounds like to me.hope this helps
Mar 29, 2014 | 2003 Kia Rio
How to install new bearing
What bearing, what kind of tractor. If you're referring to spindle bearing for blades, then you would remove the spindle housing from the deck after removing blade. Remove bearing retainers and press shaft/bearings out. Need model numbers and brand to be of more help.
Aug 17, 2010 | Garden
Left front hub replacement 2WD.
2WD pickups don't have hubs. They have rotors with bearings. Once you have the brake assembly supported, remove nut from spindle. Be sure not to strip the threads on the spindle. Remove the front set of bearings and pull the rotor off. Remove the rear set of bearings. Be sure to pack greases into new bearings prior to installation. Insert new rear bearing into rotor and replace onto spindle. Insert new front bearing and washer and re-install nut. Tighten to recommended torque specs, grease fittings and replace brake assembly.
May 15, 2010 | 2005 Chevrolet Colorado
Do i need any special tools to change hub bearing on a 95 honda passport
No special tools needed, this Honda has the old type inner and outer wheel bearing's, remove cotter pin, spindle nut slide rotor out, remove wheel bearing, repack new bearing with grease and don't forget to replace grease seal's, install new part's adjust spindle nut and install cotter pin.Good luck,hope this was very helpful.
May 13, 2010 | 1995 Honda Passport
How to replace a front wheel bearing
You'll need to remove the wheel, seperate the tierod end from the wheel spindle, remove the cailper and carrier from the wheel spindle, remove the axlenut, and unbolt the 2 bolts holding the spindle to the strut housing. You need to press out the wheel hub and remove the clips on either side of the bearing and press out the bearing from the spindle.
May 02, 2010 | 1996 Volkswagen Golf
Replacing front wheel bearing
The brake rotor needs to be removed, drive shaft nut in center of hub then 3 bolts hold the hub assembly to spindle from back side. if it has abs unplug it then some work will need to be done with a hammer and chisel to work the bearing out of spindle and axle shaft from bearing
Oct 16, 2008 | 2001 Buick LeSabre
Anybody got a spindle?...
I'm not a mechanic. But since you've had no answer, here goes.
Each wheel bearing replaced contains a race and bearings of its own. If your mechanic replaced the cup that the bearing sat in (steel ring with a tapered inside that matches the angle of the rollers) then there is nothing more to do with the wheel bearings to make the bearings last.
Now the steering on the other hand... The axle goes through the wheel hub horizontally - allows forward rolling for the wheels. The steering needs a similar thing, but it can't use an axle as there is already one going through the hub. For the steering, picture a big hand that grips your wheel hub, holding only at the top and bottom. Where the fingers and thumb (ie the spindles top and bottom) met the hub, there needs to be some sort of bearing or sealed pivot point as well. This allows the hub to turn when the vehicle is steered.
This may be what he was talking about, and it is quite feasible that some of its components may need replacing as they are a load bearing point. But... I wouldn't have thought it would extend the life of your wheel bearings drastically as they do different jobs. Have a chat to the mechanic to clarify what he/she said. I don't think they are being dishonest - maybe exaggerating the requirement a little.
Benefit of the doubt. Hope this helps. Phil
Aug 17, 2008 | 1989 Ford Festiva
Candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Jun 12, 2008 | Candy AQW130 Front Load Washer / Dryer
Toro 50''  Zero Turn Lawn Mower Trailer Package Deal () Logo
27 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
