Question about Precor EFX 546i Elliptical Version 4
EFX5.21si ramp goes up but not down - Precor EFX 546i Elliptical Version 4
Fans work but only after it gets warmer than it usually runs 2003 dodge caravan. The code is slow fan not working is there a separate fuse or switch?
DESCRIPTION The dual radiator fans are mounted to the back side of the radiator . The radiator fan consist of the fan blade, electric motor and a support shroud which are all serviced as an assembly.
OPERATION COOLANT TEMPERATURE
A/C PRESSURE TRANSAXLE OIL TEMPERATURE Fan Operation Speeds: Initial Max Initial Max Initial Max Fan On: 104°C (220°F) 110°C (230°F) Fan Speed Duty-Cycles (Ramps-up) from 30% to 99% 1,724 Kpa (250 psi) 2,068 Kpa (300 psi) Fan Speed Duty-Cycles (Ramps-up) from 30% to 99% 96°C (204°F) 111°C (232°F) Fan Speed Duty Cycles (Ramps-up) from 30% to 99% Fan Off: 101°C (214°F) Fan Speed Duty-Cycles (Ramps-down) from 99% to 30% 1,710 Kpa (248 psi) Fan Speed Duty-Cycles (Ramps-down) from 99% to 30% 89°C (192°F) Fan Speed Duty Cycles (Ramps-down) from 99% to 30%
Mar 08, 2018 | Dodge Cars & Trucks
Tip
Driving cars up ramps on slippery surfaces
I cant take credit for this one, but I do have an improvement. do your ramps "skate" accross the smooth garage floor as you try to drive up them? Same thing in gravel? An old tie down or seat belt strapped to the top of the ramps and placed under both wheels on the same side of the ramp will stop it from sliding away. For better results, my improvement is to fasten the strap around the drive wheel so it is essentially a pully making sure the ramp goes under the wheel.
*****disclaimer Note that ramps are really dangerous, make sure there are other people around, underneeth, infront, behind, or anywhere else. be careful, its easy to launch off ramps or put them all the way underneeth the car.
on Jun 22, 2010 | Cadillac Brougham Cars & Trucks
Tip
Safety concerns with car ramps.
Alot of people feel just a little bit uneasy when it come to getting under a car when on car ramps. A little trick is to drive the car on the ramps, put blocks, or wheel chucks behind the grounded tires. Then using a jack, jack one of the ramped tires up enough to remove its ramp. Reverse that ramp and then lower the vehicle down. It can't roll down the ramps because it is wheel locked inplace. Please though reverse that prcedure to drive it off the ramps.
Please note, I selected Chevy as the manufacturer only because 'any' is not an option
on Dec 08, 2009 | Chevrolet Chevy Cars & Trucks
When my daughter goes down a ramp the wheelchair tilts forward and the back wheels are off the ground! Why is this happening?
ramp too steep and not made to a safety standard
person too high in chair
person too far forward in chair
front wheels not positioned far enough forward
carer not paying attention to the ramp and possible risks
talk with disability persons equipment retailers as they have a good idea of the risks involved with wheel chairs and can advise you on how to overcome the problem
Jun 21, 2016 | Health & Beauty
Precor 5.17i lift wobbly
INcline it all the way up and look underneath the ramp. Check where the ramp attaches to the main frame. If there are cracks in the bottom of the ramp, you need a new ramp, especially if you have a steel ramp as opposed to alumunum.
Mar 14, 2014 | Precor Exercise & Fitness
Ramp goes down, will not come back up
what a handicap ramp? most have a 6 pole switch that can burn out easily if its not heavy enough.. contact the ramp manufacterer for details...
Jan 17, 2013 | 2007 Toyota Sienna
The ramp will not go up or down. It's states low battery (546i precor)
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
50pc5d LG plasma TV Blue glow/red pixels
THIS PHENOMENON IS A CHARACTERISTIC OF PLASMA TV SETS...KNOWN AS DIFFUSION ERRORS OR COMMONLY..SPARKLING...ON LG SETS...THE PANEL VOLTAGES MUST BE CHECKED AND ADJUSTED IF NOT WITHIN .5 V...PLUS OR MINUS..Vs...and Va...THE OTHER ADJUSTMENTS ARE ON THE Y-SUS BOARD..Vset DOWN...Vset up...RAMP up...RAMP down...these should be adjusted by professional tv personnel with experence...JOE ACE
Mar 05, 2008 | LG 50PC5DC 50 in. Plasma HDTV
Precor EFX 546i Elliptical Version 4 Logo
48 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
