Question about LG 26LX2D 26 in. LCD HDTV
Connecting Rabbit Ears
My mother has recently purchased a new LG TV. This is a serious step up from the 13in TV before. The problem I have trying to set it up for her is getting her rabbit ears to show a signal on the LG. I know it's not a problem with the reception, picture was fine on the other TV. I tried running the EZ Scan, but that didn't bring up any channels. I've also noticed that I can only get to three channels on the LG, (15, 16, 17) unless I key in specific numbers to get to other channels. I'm hoping this is going to prove why she should get a better piece of tech to get signal, but until then, any help would be greatly appreciated. J
    Scholar:
  • 125 Answers
If you are going through a VCR, make sure you have it in Port 1, or the primary connection. Sometimes they are sticking out the front and people use the alternate port at the back for tidyness, then it won't work.
Posted on Aug 03, 2007
SOURCE:
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
Want to set this up without cable. Someone told me to go to "air" mode and add rabbit ears and this will work. I cannot find an air mode on this tv. How do you set this one up with rabbit...
You will once again, purchase a converter box to receive an over the air channel. I don't think you will have to really worry about using an over the air mode on the TV. It may be in the menu, but will work otherwise after being placed on channel 3 to receive through the converter box. The rabbit ears will be connected to the converter box itself.
Feb 13, 2011 | Televison & Video
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Trying to get DTV, I can't figure it out
If you are in the US you need a digital reciever, rabbit ears or otherwise and have since February. That when all US broadcasters switched to digital broadcast. If it's more than about 5 years old you will likely have to purchase a new TV.
Jun 02, 2009 | Akai LCT3201TD 32 in. LCD Television
Tv set just lost its ability to display digital channels
Your problem is definitely the input signal source to your tv. It is extremely rare where a new tv has a tuner signal sensitivity problem. The best thing to do is to replace your current set of rabbit ears with a different set of powered rabbit ears that have a higher gain rating with a variable gain control. Please note that the gain control setting is critical when setting up your tuner for auto-programming. If the gain control is set too low or too high it will result in your symptom.
If you still can't get it to work you could try buying a line amplifier which you would install to the rabbit ears before the tv. If you still can't get it to work you'll have no choice but to purchase an outside antennae as a result of your being in a weak signal area as signal quality changes by such things as the switch over to digital upcoming and environmental changes.
Apr 27, 2009 | Televison & Video
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
LG 26LX2D 26 in. LCD HDTV Logo
178 people viewed this question
Ekse
RONALD CARTER JR
