Question about Gateway GT5014 PC Desktop
Gateway gt 5014 wont boot up
Turn pc on fan starts monitor comes on an saya no signal then screen goes blank can not get pc to go intof2 or f8 need help to see what is wrong t/y
    Problem Solver:
  • 13 Answers
The problem may be your video card.
Posted on Mar 12, 2009
I HAVE BEEN GIVEN A LT 456s MONITOR AND AM TRYING TO HOOK UP TO A GATEWAY COMPUTOR WITH WINDOWS XP- WHEN I TURN IT ON THE GATEWAY WINDOW SHOWS UP AND THE THE WINDOWS XP AFTER THAT IT IS BLANK UNTIL A NO...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 14, 2010 | Computers & Internet
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
Mar 31, 2009 | Gateway M305CRV Notebook
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Have an old Gateway PC - message "FREQ. OUT OF RANGE", then the screen goes blank
Start tapping the F8 key during boot, and choose Safe Mode right click on the desktop to get the dropdown menu then go to properties click on the settings tab then the advanced tab then the monitor tab and lower the screen refresh rate click apply
May 07, 2008 | Computers & Internet
Gateway GT 5014 desktop not booting
Well make sure abt the Rams and the Video cards first, Remove your Rams and video cards and install them back.,,,,,, And make sure ur monitor is working as welll .....
Nov 07, 2007 | Gateway GT5014 PC Desktop
Monitor Goes Black
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Aug 08, 2007 | Gateway FPD2275W LCD Monitor
Gateway GT5014 PC Desktop Logo
164 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
