Question about Toshiba CX35F70 35" TV
Channal selector down
Tv works in video mode, but when tried to select a channel I only get a blue screen, any guees?
Sounds like it is changing to another video mode that has no input so the screen is blue. On many tv's the channel buttons also act as video input button. This should happen with the buttons on the tv. If you are using the the remote I am not sure why it is acting like a video input button. Try changing video to tv with one and changing the stations with the other. I take it you are watching antenna tv and not using cable box or satellite. If this does not work and you have old vcr just use it as a tuner to change your channels.
Posted on Aug 03, 2007
  • mark burch Aug 03, 2007
    Make sure you first of all have the remote button pushed to control the tv. Sometimes with universal remotes people simply bump aux buttons so it seems as though nothing works. Push tv then channels...
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Sep 15, 2011 | Sanyo AVM-3259S TV
The screen is blue. channels come up but no
Are your sure you're on the right channel (3/4) did you try the video inputs? ie. use video out from Satelite to video in on tv and select the video input on the tv
Sep 30, 2009 | Apex Digital AT2002S 20" TV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Cannot locate an input selector to change from cable to a recorder
Try selecting channel 00 enter on remote.....I am assuming
you are missing the original GE remote that has an input button
on it ............? Let me know.........T.
Dec 22, 2007 | GE 31GT659 31" TV
Video screen
the tv is set in the video mode! select it to the TV or air mode! use your remote control then select the TV air mode.
Oct 02, 2007 | Sanyo AVM-3659S 36" TV
HELP!!!
Go back in the menu, find (input source) or (tuner) then click the cursor right side of the menu button or the left to move the (TV) to (CATV), after you bring it up then move cursor arrow up or down to page (AUTOPROGRAM) then tap the cursor arrow right of the menu button to start the CATV channels to be found , be sure you have the cable connected to the TV. Once the channels have been found, tap (EXIT) or (STATUS) button on remote to get out of the menu and close the page, or just turn set off and back on again.
May 29, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
