Question about Whirlpool 2198202 Thermostat for Refrigerator
How to calibrate thermostat on 2198202 thermostat
Purchased a replacement thermostat and the unit does not seem to shut off. How do I calibrate the thermostat so it cycles correctly?
2 Suggested Answers
  • 82 Answers
SOURCE: Installing themostat for Whirlpool
Usually there are some screws that are at the area where the dial is. If it is the type I am thinking of it has a long capillary and two areas where the wires plug into. If you take off the wires you can usually follow where the capillary is and intall it. It is pretty self explanitory once you get the screws out. If this doesn't help you, can send me a picture and I can go from there.
Posted on Jan 12, 2009
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
My side by side is freezing everthing solid. I have turned it all the way down, but it acts like a freezer. Even the eggs are frozen solid.
That sounds to be like the thermostat is sticking and no matter where you set it,it's cooling to the maximum setting.the thermostat should be replaced. The part number for it is 2198202 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
Gene
Aug 14, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Fryer heats up but does not maintain proper temp. last year replaced hi limit reset & today replaced thermostat
Hi there.
You may need to calibrate the new thermostat and in doing so, you will need a calibrated thermometer with sensor dipped in oil at about one (1) inch above the fryer thermostat sensing bulb.
Record the cut-off temp (when indicator light goes off) and compare it with the thermostat setting.
The thermostat has a calibration screw ( - ) recessed in the middle of the shaft, you will see the when you pull off the thermostat knob. this calibration screw can be turned by a precision screw driver, turn clockwise to decrease the cut-off temperature ; turn counterclockwise to increase the cut-off temperature.
Just make sure that the unit is preheated or have cycled at least 5 to 8 times and the oil is new before performing the calibration.
Regards.
Jul 14, 2011 | Wells F-101(21186) Deep Fryer
My sg-14 pitco frialator heats fine for about an hour and then shuts off. I have to turn it on again, as it has shut down completly. I have replaced the main thermostat probe, but the problem continues,
Hi there.
Make sure that the gas pressure being fed to the unit is sufficient or meets the required pressure on nameplate.
Try to check the hi limit it it has continuity across the terminals (with wires removed during checking) when it shut down, if the hi limit has continuity across the terminals- it is good; if it has none- it is tripped so check the oil temperature, hi limit trips at temperature around 450F. Verify also the temperature setting and the thermostat calibration.
If the unit has thermopile, it should be free of soot or any form of dirt. All wiring connection must be tight.
For calibration procedure, wiring diagram and other troubleshooting references, you can visit http://www.pitco.com
Regards.
Jul 13, 2011 | Pitco Frialator Kitchen Appliances -...
Fryer will heat up at 350 temp setting but actual reading is 375. The problem we are having is that the fryer will heat up fine then when the burner goes of the pilot will also shut off. If however i run...
The thermostat is out of calibration and the hi-limit may be as well. I could give you instructions on calibrating the thermostat but the hi-limit is not adjustable at all. The hi-limit cuts off the burners and pilot in the event that the unit gets close to the flash point of the cooking oil. It should not cut out until 400-425 so either the fryer is occaisionally getting a lot hotter than you think or the hi-limit has gotten weak due to the erratic operation of the thermostat. I would recommend that you change both the thermostat and the hi-limit.
Dec 09, 2010 | Vulcan EF3 Deep Fryer
Whirlpool 2198202 Thermostat for Refrigerator Logo
22 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
