Question about GE GTH18EBT Top Freezer Refrigerator
Gth21scxass turned off won't come back on - GE GTH18EBT Top Freezer Refrigerator
The back light won't turn on and the volume is turned all the way up but the buttons won't work for me to turn it down. I had to take the whole thing out
Assuming your deck is a kdc 516s the flexible cable that goes from the face to the main motherboard is probably bad. If you are not good at desoldering and soldering. , I would suggest you have it replaced by a professional.
May 06, 2012 | Kenwood KDC-516S CD Player
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
May 06, 2012 | Dell Vostro 320 Desktop Computer
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have a 91 olds supreme 3.1 v6 it shut off and won't start back .... It starts but won't turn over.... And when turn the key back off it's blows the dis fuse wich mean direct ignition system...
Check the coils that have been replace for bent or broken prongs that plug into the ignition control module and if nothing looks damaged then i would think the ignition control module is faulty.Replace ignition control module.
Jan 21, 2012 | 1991 Oldsmobile Cutlass Supreme
Back brake caliper's piston won't compress for me to put on new pads
if your turning the piston the right way which you probably are so it turns in not out and it won`t go back then it sounds like caliper needs to be replaced as the piston is siezed in its postion.
Nov 08, 2011 | 1994 Ford Taurus
It turns on and comes onto a report problem so i send it but sometimes a report problem doesn't come up nether the less either way it starts for about 7 seconds then just freezes won't let me move...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
GE GTH18EBT Top Freezer Refrigerator Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
