Question about Toro Garden
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Model # 20332
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Posted on May 06, 2013
  • 1129 Answers
SOURCE: Toro lawn mower. Have trouble starting(starts and
Remove the float bowl located under the carburetor it is a 1/2 bolt some gas will poor out so put a rag under the carb to soak up the gas, you actually may want to use a small container to collect the gas or make sure the gas tank is empty, remove the float bowl after removing the bolt by grasping it and turning, the bowl will most likely have debree and water in it clean with a rag and solvent and reinstall, becareful of the ruuber ring gasket when reinstalling the float bowl, one some movers there is no float bowl if you have this type of engine the tank and carb must be removed disassembled and clean out. Do not store mowers uncovered they must be covered when not in use, water gets into the fuel system and causes this problem.
Posted on Jul 14, 2009
  • 143 Answers
SOURCE: Non-starting Toro lawn mower
If the mower was lying up for a time you will need to remove and clean out the carburettor and fill with fresh fuel.Stephen.
Posted on Nov 09, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
  • 15483 Answers
SOURCE: I have a lawn mower that needs a spark plug. I
reason for different plugs are because motors require different lengths ,temperature,design etc-it may run now but if its to long-or short can cause engine problem or damage-same for hot or cold can burn valves-or carbon up valves or plug -change it to the recommended plug mower will last longer with correct replacement parts
Posted on Mar 13, 2010
2strokeJim
  • 577 Answers
SOURCE: what is the spark plug gap for a Toro 450, GTS2
most generally out of the box your good to go! not like the old days !
Posted on May 17, 2011
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Where do I find and how do I replace the spark plug wire?
spark plug wires are attatched to the coil. to replace the whole plug wire you need to change your coil. The boot can be replaced by itself but only if the wire is good
Oct 18, 2014 | Toro Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Can you use a champion spark plug rdj7y in 6.5 silver series lawn boy mower
Anthony you can use any kind of spark plug brand as long as its the same size. Sometimes they have a longer sparking element and this will catch on the piston. Just be careful.
Sep 10, 2013 | Champion International Lawn Mower Champion...
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
I have an old Craftsman lawn mower and just need to verify that I have the correct spark plug and what the gap should be.
You have not given any specs on what engine you have (Briggs? Tecumseh? Craftsman uses both on their machines), but most of the ones I fix use the same old standard Briggs spark plug, which is a Champion J19LM plug gapped at .030. (The Champion is not required, just the most common and you can cross-reference it to other brands. If you provide your engine make and model, then I can tell you exactly what to use.
James
Aug 10, 2011 | Garden
Garden Logo
1,187 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
