Question about Whirlpool 2198202 Thermostat for Refrigerator
How to calibrate thermostat on 2198202 thermostat
Have a replacement unit and want to be sure it is calibrated
2 Suggested Answers
  • 82 Answers
SOURCE: Installing themostat for Whirlpool
Usually there are some screws that are at the area where the dial is. If it is the type I am thinking of it has a long capillary and two areas where the wires plug into. If you take off the wires you can usually follow where the capillary is and intall it. It is pretty self explanitory once you get the screws out. If this doesn't help you, can send me a picture and I can go from there.
Posted on Jan 12, 2009
No temperature control on hot plate elements. Is this fixable?
ADJUST OVEN FLAME LEVEL: Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat. The reason for my free advice is GOD is good!
Dec 16, 2016 | Ovens
How to calibrate oven?
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
Dec 01, 2016 | Ovens
Lost measuring cup
follow this test and fix it. God bless you
If the toaster doesn't work at all, make sure power is on at the electrical receptacle and test the power cord.
If the carriage lowers but doesn't latch or latches stiffly, look inside for food debris that may be blocking the carriage. If the latch is damaged or obstructed, service the assembly (see below).
If the bread toasts only on one side, check the heating elements for damage and replace as needed; or replace the toaster.
If the carriage doesn't pop up and the toast burns, check the thermostat calibration and correct any inaccurate calibration (see below).
If the thermostat is faulty, replace the thermostat or the toaster. Check the solenoid switch and solenoid; if faulty, service (see below) or replace.
If the toast is too light or too dark, check thermostat calibration and correct if necessary (see below)
Nov 14, 2013 | Back to Basics Kitchen Appliances - Others
Pronto not getting hot enough
need to calibrate the thermostat, usually requires unattaching the thermostat from the unit and adjusting the calibration adjustment screw or lever (older units), if electronic sorry cant help ya as i am an old school tech
Jul 09, 2012 | Microwave Ovens
Fryer heats up but does not maintain proper temp. last year replaced hi limit reset & today replaced thermostat
Hi there.
You may need to calibrate the new thermostat and in doing so, you will need a calibrated thermometer with sensor dipped in oil at about one (1) inch above the fryer thermostat sensing bulb.
Record the cut-off temp (when indicator light goes off) and compare it with the thermostat setting.
The thermostat has a calibration screw ( - ) recessed in the middle of the shaft, you will see the when you pull off the thermostat knob. this calibration screw can be turned by a precision screw driver, turn clockwise to decrease the cut-off temperature ; turn counterclockwise to increase the cut-off temperature.
Just make sure that the unit is preheated or have cycled at least 5 to 8 times and the oil is new before performing the calibration.
Regards.
Jul 14, 2011 | Wells F-101(21186) Deep Fryer
My Super capacity 465 is not cooking at the right temp. It is about 25 degrees off. is it a thermalstat?
most likely yes... there is a thermostat probe that probley needs to be replaced... however 25 degrees is not to far out... some of these units you can get into the control settings and calibrate... if nobody else has ever worked on unit normally there is some literature in the control area behind the panel that is for the servicer and it should tell you how to get into setup and adjust/calibrate the temperature and offsetr it by 25 degrees... you are just reprogramming unit... if that doesn't help then get a new thermostat... good luck to you ....
Jan 12, 2011 | Whirlpool Ovens
Furnace keeps going off. Thermostat and Inducer assembly recently replaced.
Thermostat needs to be level and has to be calibrated. Check filter to make sure it is not plugged - you may need to relace it. If it is not plugged - make sure it is the correct filter for unit. Owners manual should tell you what filter to use.
Jan 03, 2011 | Heating & Cooling
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
Whirlpool 2198202 Thermostat for Refrigerator Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
