Question about Thetford RV Refrigerator - N300 Model - Type - 3-Way
Refrigerator on rv keeps going out
It works fine on ac. all other appliances work fine on propane. the tank is 3/4 full the flame will go out and the check light comes on sometimes it will stay lite for 2 hours sometimes for 2 minutes. it dosn't make a differance if I'm on the road or parked
  • Ybnsane May 17, 2009
    My Norcold N300 won't stay lit for longer than 15 minutes even after replacing the thermocouple. The burner is clean.
  • 400 Answers
Two reasons, first would be that the burner is dirty and needs cleaning. Second is that the thermocouple is either faulty or incorrectly installed. By this I mean that it might be slightly too far away from the flame to be able to conduct sufficient heat to keep the thermocouple open. This can happen when you park or drive and the rv is at different angles. So the flame does not heat the thermocouple enough and it shuts off the supply.
Posted on Mar 12, 2009
Norcold had my repair person replace the burner assembly and wiring harness - that fixed the problem - after lots of thermocouple and other replacements that did not work. Seems Nocold made a change and knew about the problem - just didn't tell anyone.
Posted on Jul 04, 2009
Can you get water in LP lines when filling RV w/ propane? Frig quit on propane,worked on electric. Had filled w/ propane two days earlier. mechanic found oily water in line; range still worked.
Yes water can do compensation build up in your propane tank. Some tanks have a drain pit on bottom reclaim propane and open the pit. If your does reclaim the propane and drain tank. If not reclaim propane and remove tank then remove filler valve turn tank over drain access water leave tank up side down over night. Put fill valve back on and mount tank. After lines are back on turn stove on leave on for 48 hours. Turn valves off and refill tank. Best of luck.
Jun 10, 2016 | RVs
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Oct 11, 2013 | Dometic RM2652 Refrigerator
I have a Dometic RM3801 rv fridge that was working fine on 120v and then stopped cooling. All the lights come on but the compressor won't run. It is level and the cooling fins are clean. I checked power at...
your refrigerator is an ammonia absorption system it does not have a compressor only a series of closed pipes and small tanks located behind the styrofoam box so; to operate yout refrigerator you need: a propane flame or, a 12 volt heating coil or an AC transformer to heat the system depending on if you have a 1,2,or, 3 way system.
also; these refrigerators will only work if you are on level ground
so check your fuses, transformer and, or, your gas thermocouple:
the thermocouple is a rod that sits in the burner flame to control the gas valve if you see some yellow dust around the back of the refrigerator you have a leak of the sealed system don't buy a new refrigerator just replace the system and, be sure that you remove the twisted metal riser in the top of the refrigerator vent pipe to use in your new system or, nothing will work the ammonia absorption sealed systems can be bought on ebay etc.
Sep 25, 2013 | Refrigerators
8/11-1997 motor home dometic rm2310 3-way frig: 2 days ago i got a nice blue flame for the gas operation.now, i can't get gas to flow to the burner to ignite the burner. that is when the gas is turned on...
Few items to check first.
Inspect propane regulator.
#1 Is the RV on level ground?
#2 Purge the air pocket in the line. Turn on all you stove heads. Let it burn for 3 minutes to eliminate air pocket on propane line.
#3 Inspect for leak marking on the outside panel.
Aug 11, 2010 | Refrigerators
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Connecting Reddy HD30 to RV Propane Tank
pipe feed could be too small poor flow of gas or flamesafety is cutting in
May 26, 2010 | Reddy HD30 Heater
You probably have a dirty pilot safety. Clean the pilot with rustbuster.
Mar 12, 2009 | Refrigerators
Dometic RM3862 RV Refrigerator
This happens when your electrode fails. Replace your electrode.
Jul 25, 2008 | Dometic Refrigerators
Thetford RV Refrigerator - N300 Model - Type - 3-Way Logo
1,368 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
