Question about Delta 50 - 760 1.5HP Dust Collector
Delta ap400 motor wont start - Delta 50 - 760 1.5HP Dust Collector
2 Suggested Answers
  • 10 Answers
SOURCE: looking for wiring diagram for AP400 Delta dust
http://www.ereplacementparts.com/delta-50840-type-dust-collector-parts-c-3275_4081_13806.html
According to this page, You will need new switch, item 17.
Hope that helps,
Posted on Jan 23, 2011
Delta scroll saw won't startup
check to make sure the tension isn't too tight, loosen and see if starts moving, if not then the motor is bad
Dec 17, 2015 | Delta Measuring Tools & Sensors
I have a Delta Model 23-660 that won't start anymore. For awhile, if I gave the wheel a spin by hand it it would start, but not not at all. I'm assuming brushes? If so, what brushes would it take? The...
  • there is also an
  • centrifugal circuit inside one- side of the motor electricfield (not in the spare parts to see or order) that could have a problem but first measure the capacitor
  • There are no brushes used its an induction motor. with start capacitor and an centrifugal switch. that was when you give a swing to the grinder the capacitor you needed has an 8 or 10 microfarrad 250 volt AC to start i think but be shure the start centrifugal is in good order and the capacitor together.
  • Delta 23 660 Type 1 Grinder Parts
Feb 27, 2015 | Delta Grinders
Can I Run 3 Phase Motor On Y Or Star Connection Without A DELTA?
Some motors need a Y and Delta, with a special switch, to start up, you start with the Y. the motor starts turning, but does not give full power. after a few seconds (depends what the manual says) you switch to delta, to get full power. To let it run on full power in Y you need 1,4 times the voltage.
If everything runs fine, you won't have damaged anything.
Jul 13, 2014 | Baldor RM3120 HVAC Fan and Blower Motor,...
Need P/S voltages for a Canon AP400 t/w
The power supply requirements should be provided if you look on the typewriter.
Apr 23, 2012 | Office Equipment & Supplies
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Who to wirie star delta starter
This site gives an excellent explanation of the star connection and the delta connection.
Answers.com - How do you wire a star delta motor
Then this site shows the wiring of the motor windings and the star delta starter and what occurs when the starter switches from star to delta.
Moeller - Star-delta switching of three-phase motors - Automatic star-delta starters SDAINL
Good luck.
Dec 20, 2010 | Air Tools & Compressors
What is the use of wye delta?
I don't know why your question is bound to this special breaker.
If your question is common, the wye/delta is a way to reduce the starting current of a large three phase asinchronous motor.
When a three phase motor is first connected in wye (star), the starting (peak) current is about 3 times less than this in delta. When already in motion the electromotive force will make the peak current when turned in delta much less, than that with a stopped motor.
Aug 08, 2010 | RTO Telemecanique Gv2 Ls22 Magnetic...
I have 1988 oldsmobile delta 88 iwas driveing it and it died and
you have to have fire,fuel,compression for an engine to run,check those
Jun 16, 2009 | 1988 Oldsmobile Delta 88
Delta 50 - 760 1.5HP Dust Collector Logo
Top Delta Tools & Hardware - Others Experts
Jim London
Jim London
Andrew Taylor
Andrew Taylor
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
