Question about Coffee Makers & Espresso Machines
I picked up cuisinart coffee maker and model pg 15157a and need to know about a few things about it
Need to read the Manul
  • 19 Answers
SOURCE: Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Posted on Jan 19, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
freetek
  • 5568 Answers
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Posted on Jul 15, 2009
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
My cuisinart em200 will not turn on.
Seems like this model has alot of issues based on what I am reading on the internet.
First thing you should do is make sure that your plug is working by moving your Cuisinart to a plug that you know is working or plugging something in that same plug that runs, so you know the breaker or GMI switch isn't tripped. Next, contact Cuisinart for assistance. I located the manual and it says nothing about troubleshooting issues like this. Contact information is included in the manual though, so here it is: https://www.cuisinart.com/share/pdf/manuals/em-200.pdf
Hope this helps.
Apr 29, 2018 | Cuisinart Coffee Makers & Espresso...
Hi I need instructions for cuisinart grind and brew PG-22617-UK
http://cuisinart.conairspares4u.co.uk/how-and-where-to-find-your-product-model-reference-en.html
Feb 11, 2015 | Cuisinart Coffee Makers & Espresso...
Need cuisinart coffee maker manual model DCC 11008K
contact Cuisinart Coffee maker via google, they will help.
Sep 30, 2011 | Cuisinart DCC-1200 Coffee Maker
Need instruction manual for 10 cup Cuisinart coffee maker
You did not specify your model number but you may be able to find a manuaj for your coffee maker online here:
http://www.cuisinart.ca/cuisinart_manuals.php?cat_id=2
Jun 02, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Automotic Grind & Brew Coffee Maker
http://www.cuisinart.com/manuals/index.php?item_id=34
Jun 02, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Jan 28, 2008 | Cuisinart DCC490SA Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
