Question about Acer Extensa 5635 Notebook LXEEA03007
I have an acer extensa 5635 with a full battery that wont turn on.
Power led indicator flashes orange once, 10 seconds after pushing the power button.
  • Acer Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Apr 21, 2013
  • 82 Answers
SOURCE: Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Posted on Apr 22, 2009
  • 16 Answers
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Posted on Aug 23, 2009
Testimonial: "Exactlt what I had been thinking!"
  • 37 Answers
SOURCE: My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Posted on Dec 09, 2009
  • 26 Answers
SOURCE: Acer Extensa 5420-5687 laptop won't turn on
Okay, Here's the deal..... I recently had the same problems with my friends' Acer Extensa laptop and here's what I did to fix it. I narrowed the issue down to two culprits 1. Overheating, 2. Defective Motherboard. I have fixed the problem but I takes time, patience and some technical ability which may not be available to some. :( (Swapping out the motherboard MAY fix the problem but if the defect is in the manufacturing process then the problems could return). Here's how I fixed it... While in the process of disassembly I noticed a small electrolytic capacitor that had seemingly broken off and had become wedged between the frame (<ital>very lucky! this gave me the clue I was looking for!</ital>). This made me think that it had broken off the motherboard. I proceeded to disassemble the laptop and found the location of the missing capacitor (there are two located right next to each other on the board) and was able to re solder the capacitor back onto the motherboard (could it be a manufacturing processing defect thats causing these to break loose? ). Mine was broken off due to what looked like bad solder joints. Your capacitors could still be attached but have weak solder connections. Also while i had access to the motherboard, I used the opportunity to clean and re apply the heat sink compound to the CPU and thoroughly clean the fan vents. I then reassembled the laptop and EVERYTHING has been running fine now for the last 3 days. Total time was about 4hrs and it cost NOTHING to repair. GOOD LUCK :)
Posted on Mar 14, 2010
SOURCE: Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Posted on May 11, 2010
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Tip
Dell Portable Battery LED flashes Orange 4 times then Green once
This LED flash pattern, Orange, Orange, Orange, Orange, Green (Repeats) indicates a internal failure of the Battery. Pressing the charge indicator button on the battery (If equipped) will give a 1 3 5 LED on indication which also indicates a failure in the battery.
The battery may still function, but at less than optimal performance and will have a progressively shorter functional life until it dies.
The only way to resolve the issue is to replace the battery.
on Dec 23, 2009 | Computers & Internet
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
Acer Extensa 5235 wil not power on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Extensa 5235 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Extensa 5420-5687 Notebook
Acer Aspire 3050 will not boot - LEDs flashing 8 times
My Gateway did that it was due to the power adaptor being loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Aug 26, 2009 | Acer Aspire One A150-1006 Notebook
My acer Notebook Does not switch on
Well you can reseat the RAM and check if that does not fixes the issue, it could be an issue with the system board . You can contact Acer support line, if the unit is under warranty you can have system board replaced.
Jun 29, 2009 | Acer Extensa 5420-5687 Notebook
My charge light constantly flashes orange and my C600 won't turn on at all. I hold the power button and all the lights turn off. I got nothing. Just a blankscreen.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
Apr 08, 2009 | Dell Latitude D600 Notebook
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Acer Extensa 5635 Notebook LXEEA03007 Logo
310 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
