Question about Whirlpool Dryers
Whirpool dryer does not dry clothes
The tumbler still rotates and the clothes do get hot, but not actually dry. I just put in a new belt as well.
  • Whirlpool Master
  • 7,482 Answers
Hi Peter
Here are a few things to check
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Posted on Apr 21, 2013
Testimonial: "Yes, it was lint in the hose, was I cleaned it out it worked just fine. Thanks."
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
SOURCE: dryer
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
Posted on Sep 22, 2008
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
  • 10 Answers
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
Maytag dependable care quiet plus ii
Hi, The belt should be in a straight line from the motor to the drum.
If alignment is not corrected damage to belt may occure.
Normally if all parts are working properly the belt should align itself.
Make sure that belt is not rubbing on any other parts. (slowing motor down). Lube all moving parts with lube oil. Don't put oil on belt.(only on bearings of motor and drum).
Jan 20, 2014 | Dryers
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Jan 19, 2011 | Whirlpool Dryers
LGR5636kq0 model. not drying clothes reasonable time
It could be the tumbler. Also check the vent coming from the back of the dryer (make sure it is not clogged)
Nov 10, 2009 | Whirlpool LGR5636L Gas Dryer
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Drum problem
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Feb 21, 2008 | Dryers
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
1,165 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
