Question about Apple iPhone Smartphone
My net phone will not ring only vibrate how do i fix it?
My phone will only vibrate.i have done what the book that came with it said but it still only vibrate.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Apple Expert
  • 111 Answers
Make sure that the switch on the side of your phone is flipped on. That can silent your phone even if it is set to ring in the settings.
Posted on Jun 05, 2014
My SAMSUNG SGH-F250L is not vibrating when it rings. Why?
Hi Pretty girl,
Go to your 'profiles', select on it. Your current profile would be highlighted, seect it. Then you would see an option to 'personalise' the profile select it. Among the list of options, you would see 'vibration' option. Set it to 'vibrate'. When you are done, remeber to press save/done/ok.
Then when next the phone rings, it would vibrate.
I hope that helped you, because you need to be happy to stay pretty.
Have a wonderful day.
Jun 23, 2011 | Cell Phones
Not able to put the Nokia E5 phone in Vibration Mode
When you get to your phone's setting, select profiles. Amongst the list of profiles, determine which of them you want to use to activate your vibrate mode.
When you have done that, scroll to that profile, select 'options', then select 'personalise'.
In the personalise sub-menu, you are allowed to set the features of that mode to your desire.
In the ringing tone, select no tone, in the ringing volume, reduce the volume to zero. When you are asked if you want to set the ringing volume to the maximum, select yes/ok.
In the vibrate option, select yes/vibrate.
In the message tone, select no tone.
For other sounds and tones, select no tone.
When you are done, REMEMBER TO SAVE IT.
Then go back and activate that profile.
It is advisable that the profile you use for this though, is your 'silent' profile.
Hope that was helpful?
Jun 20, 2011 | Nokia E5 Cell Phone
Hi Motorola defy and the ring tone doesnt make a sound when someone calls me and no its not on silent and its turned up |Thanks
Try going into call settings, then caller ID readout.
If setting is on Caller ID repeat then you won't hear ring.
Change to caller ID then ring.
Jan 02, 2011 | Motorola Mobility Defy Cell Phone
Vibration is not working perfectly,please gve me the solution
Re-soldering the Vibrat** connector will fix your problem. If there's problem with the vibrat** motor, you need to replace it. But first, restore your phone to default settings, Restart your phone and check before you proceed with the hardware.
If you have problem doing all these, better take it to a mobile repairing shop and get it done from them. Otherwise, you might make mistakes which could result in permanent damage of the handset.
Good luck.
Thanks for using FixYa.
Jul 07, 2010 | Nokia 6600
My phone won't ring aloud. It is recieving the
software fault, read here so you know what will cure it http://forums.se-nse.net/topic/39748-tutorial-flashing-a2-phones-with-a2uploader/
Mar 31, 2010 | Sony Ericsson W890i Cellular Phone
Every time i turn on all i get is vibrating found otheres with like problem but no one that can fix
Put the phone in Vibrate and ring mode so that it can ring. If you have already done so, then do you hear other sounds such as play mp3 and stuff? If you can't then it can be an issue with the speaker. If you can hear other sounds except the ring, then this is most likely to be a firmware issue. I remember downloading the P1i firmware from the Sony website for my friend's phone. You should download the Sony Ericsson Tools(SETools) for this purpose. It can be obtained from the link below.
http://www.setool.net/support/SETool2/
Regards,
Sai.
Dec 01, 2009 | Sony Ericsson P1i
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
Ring tone problem
there r three modes. 1)ring mode. 2)vibration mode. 3)silence mode. so it would be on silence mode.just make it ring mode from silence mode. which can be done by going into settings then in to ringer and volume option.in that you can select. thanks.
Jan 08, 2009 | Cell Phones
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
Apple iPhone Smartphone Logo
170 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
