Question about Boating
Problem with garmin 140 fishfinder
I installed my new fishfinder on my 22ft pontoon. I installed transducer on mount that comes on the pontoons for fishfinder. It is installed just like the instructions. My problem is the depth reading is not correct and temp reading stays at 55 and does not vary. It does not show any details for bottom or structure. I have gone through menu settings several times and tried all settings, Please help.....
Jerry from S.C.
  • 1 more comment
  • Anonymous Mar 27, 2009
    my fishfinder 140 depth just flashes 0.0
  • zeyad alanjari May 19, 2009
    hi i have the same problem with my fish finder garmin 140 when i cruse and my speed comes 2000 rpm
  • Dean
    Dean May 11, 2010
    You may need to lower the transducer further down into the water. On some boats it seems you have to do this to get a good reading. I had to do that when i had my Fishfinder 140.
5 Suggested Answers
  • 157 Answers
SOURCE: Hummingbird Fishfinder model 535
The Depth & temp come from two different sensors. Check your coax cable to the transducer (the lager oval piece), the connector, and the transducer for cracks /breaks in insulation. Good luck.
Posted on Oct 28, 2008
SOURCE: lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Posted on Jul 21, 2009
Editor925
  • 285 Answers
SOURCE: My Lowrance X-51 is not reading the depth sitting
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: My 570 quit showing the depth and continues to
I had the same problem. It was the transducer.
Posted on Aug 30, 2010
Can a hds7 be installed on a pontoon boat? If so which pontoon to put the Tran-ducer and side scan on
Transducers with side scan need to be level with the bottom of the pontoon or below it otherwise the signal will be blocked by the pontoon.
Jan 05, 2018 | Boating
Piranha 1. I want to mount it on a pontoon boat. Do I need a bracket for the transducer?
Yes, there should be a small rectangular mounting plate on the rear of one of your pontoons.
Mount your transducer on that plate. If you don't have a bracket you can order them from humminbird.
If you need it you can download a PDF file on transducer installation from the hummingbird website.
Aug 01, 2015 | Boating
No transducer
Make sure the plug that gives this unit power is secure. Also I think this device has a 2ft branch that goes to the ducer. Make sure that's right too
Apr 10, 2014 | Garmin FishFinder 240 with Transom Mount...
Have just installed a Garmin 140 on a tracker alum. boat. I have the transducer what appears to be at least 3/8 " below bottom of transom. I lose the bottom at least 40% of the time. Do I need to go...
I would recommend having the back part of the transducer a little higher (toward the sky) than the nose of the transducer. When I say a little, I mean a very slightly. This way the nose of the transducer pushes the water and any bubbles away from the face.
Sep 07, 2010 | Garmin Fishfinder 400c With Dual Beam...
What is The Maximum HP for a 22FT 1991 Legend Pontoon
check on the mfg plate.MAX rated HP might be 60 /or 75 could be more . have seen I/O,s on some even
Apr 12, 2010 | Boating
Mounting a transducer on a canoe
I used a suction cup with a bracket to attach the transducer.The suction cup is attached to a rope and when landing just pull.
Aug 30, 2009 | Garmin Fishfinder 140
I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
May 30, 2009 | Sage Colorado Pontoon Boat
Boating Logo
284 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
