Question about Gateway MX6955 Notebook
Gateway mx6955 laptop wont charge
My lap top stopped charging. when i plugged ac adapter in it still does nothing. The adapter is good, checked with meter. I let it sit not plugged in a couple days and it started charging and it worked for about an hour than shut off again and wouldnt charge again. Is there anything i can check? The ac adapter is good and i think the battery is also. Does this laptop run on ac power if the battery is removed? The purple charge lit wont come on at all.
Sager 8880 wont run on ac adapter or charge battery, has new battery and ac adapter it does work with battery but now the battery is almost completely discharged and now i get battery light blinking and...
Hi Kenneth,
Have you checked to see if the charge connector on the laptop is loose when you plug the charger into it? You can see if it is by plugging it in and wiggle it around a bit. The charge light on the laptop might stop blinking if its moved and contact is made.
Thanks,
Gary
Aug 01, 2013 | Gateway MX6956 Notebook
Ac wont charge laptop icon says plugged in but not charging? Got new Ac adapter
Battery dead? Is the cord/charger same power spec DC volts and milliamps?
Dec 24, 2012 | Computers & Internet
I just replaced my ac adapter for my gateway lap top mx 6931 thinking that was the problem for why my screen flickers when i plug my ac adpater in to charge my battery. The battery wont charge unless i...
Chances are the power jack in the laptop that is to blame. It's common for the solder connections holding the jack to the motherboard to break because of the power plug flexing. One way to check is to keep the laptop steady and wiggle the power plug. If the power indicator flickers, that's what's wrong.
The good news is that this is usually repairable. The bad news is that not all service shops are willing to get into this level of repair. The motherboard needs to be removed from the computer so the connections can be repaired. Sometimes the board needs some mechanical repair as well, and occasionally the only way to fix the trouble is to replace the board. Most shops want to replace the motherboard right off.
Call around to shops in your area and see who's willing to try soldering the board. That is usually all that's needed to get you going again.
Feb 02, 2010 | Gateway MX6931 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
How do I chaarge the battery on my lap top
1. connect the ac adapter from a known good power source.
2. plugin the battery to the laptop.
3. check bios if batt is recognize or performing normally (to do this turn on laptop keep tapping f2 to boot to the bios options)
4. just leave the laptop with the ac adapter connected and it will charge laptop automatically, just leave it for about 4 hours.
Oct 13, 2009 | Dell Latitude D600 Notebook
I puug tn cord the green light goes off wont
check if the power ac adapter pin the goes to the side of the laptop is damage, if not then try connecting ac adapter with laptop to a diff power wall socket, if fails then replace the motherboard.
Oct 12, 2009 | Dell Inspiron 1501 Notebook
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Gateway MX6955 Notebook Logo
447 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
