Question about Philips 42PFL7403D/27 42 in. LCD TV
Philips 42plf7403d/27 red light blinks on and off
3 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 15, 2009
SOURCE: philips 42FD9934 42in HDTV plasma - no Pic red light 4 blinks
tiene lus roja y no prende
Posted on Mar 04, 2011
My tv wont come on the green light comes on for a few sec then the red light comes on blinking i have a mag flat screen model num 50mf231d137
your high tension transformer is defect.
replace transformator flyback and transistor BU508AF or equal
Nov 19, 2013 | Philips 27PT543S 27" TV
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Philips Flat Panel model 32PF7320/98 error code.
4 blinks is according to the manual... POR bit / +8 V protection
In other words the 8 volt DC power circuit is going into shut down, so you would need to troubleshoot that part of the power supply
Dec 01, 2017 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 32" tv will not turn on flashing three
hi,
You have to check the power supply of you tv for any voltage missing. also check the back light inverter board for any short circuit in it. Inverter transformers in the back light controlling board can become faulty.Three blink indicate the power supply have some problem. First of all replace all the electrolytic capacitors in the power supply board. If filter capacitors in the power supply is bad then this problem can occur.
ok
Jun 09, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
Red light flashing.set will not start up.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Red light flashing
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Aug 09, 2009 | Philips 42PFL5603D/27 42 in. LCD TV
Jul 15, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Power light blinks red like 3-5 times and wont cut on
Pull the back out and check the SMPS. Check the main fuse to the AC line first.
May 25, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Help
try this code 062596 then push Menu button or to switch from comercal to consumer try this code 024995 check line line 10to see witch mode your in.
Sep 02, 2008 | Philips 27PT6441 27" TV
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 42PFL7403D/27 42 in. LCD TV Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
