Question about Orion FTDV2004 20 in. TV/VCR/DVD Combo
Orion Code for Uverse
The att uverse code book does not have the 4 digit code for the Orion TV/VCR/DVD combo. Please provide the appropriate code. I've tried all listed under any Orion product in their pamplet and none work correctly.
  • 30 Answers
1382, 3213, 1383, 3202
try one of those
Posted on Sep 21, 2009
Have you tried the auto search feature of the uverse remote? Turn the TV on and then press the TV button and the OK button at the same time on the uverse remote. after the top lights flash red 4 times then press 922 and the TV button will flash 4 times. The remote is now in the auto search mode. press the play button every couple of seconds untill the TV turns off. It may take a long time to get the remote to "learn to control your TV".
Posted on Jun 12, 2009
    Champion:
  • 217 Answers
Hi! i have a couple of codes here for your orion 0121 0135 0035 hope it would help goodluck!!!!
Posted on Jun 03, 2010
What is the code for my sony tv remote control DVD VCR COMBO
Ray, Check the attached links,remote codes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sony eSupport Remote Control Codes Programming Select Model
New 3 digit codes for DVD VCR DVR SAT TV VCR TV DVD DVR CABLE and DVR DVD...
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
Mar 08, 2016 | Sony Televison & Video
Att Uverse remote set up code for Sony Dvd player
Google for it by model numbers but I doubt you will find one that works.
Jun 14, 2012 | Sony Televison & Video
Previously Requested but no solution: I cannot reprogram the remote for this TV so that I can connect to AT&T Uverse Satellite. I do not have a mdoel number for the TV remote that came with the...
Hello, Mr. Ross.
I'll be more than happy to assist you with this and all of your other Uverse concerns.
First please write these codes down, these are the TV codes for your Mitsubishi TV,
0093, 0150, 0178, 0019 (we are going to do trial and error for these codes till we hit the correct one for your TV.)
Please turn the TV on and point your ATT remote control.
Okay, using your ATT remote control, please press and hold the TV button together with the "OK" button.
All four modes should flash twice indicating that we are programming your remote control.
Now, enter the 4 digit code and the selected mode (in our case it is the TV) should give a long flash.
Then press OK.
Try to turn your TV off and check if it would respond
If not, please redo the steps but this time use the other codes I provided earlier.
If these codes wont work we will do the automatic code finder if you are using the "black" AT&T Uverse remote control.
Using your ATT remote control, please press and hold the TV button together with the "OK" button.
Then press the "scan/ff" button repeatedly with atleast 1 second interval till it turns your TV off.
Press OK then try to turn your TV on again.
Whenever your remote won't respond, try pressing either the AT&T button on top of the remote before any other buttons or the TV button beside the ATT button.
Aug 10, 2011 | Mitsubishi Televison & Video
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
May 13, 2010 | Zenith ZEN700 Remote Control
Need att remote control mfg. no. for magnavox tv
i do not think it would work with your tv. there has been problems when tech installed uverse on dozens of tv. you can try to purchase an universal remote and see if that works. it is just like a jvc vcr/dvd player/recorder which will not work with any tv but jvc. you can also call att tech to help
Mar 05, 2010 | Televison & Video
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Dec 25, 2009 | Emerson LD195EM8 19 in. LCD TV
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Att uverse remote won't turn on yamaha reciever
Do an automatic search for your code.
  1. Turn on the device you wish to program
  2. Point the remote control at the device
  3. Press and hold the mode key (i.e. tv, dvd or aux) you want to program
  4. Without releasing the selected mode key, press and hold the OK key simultaneously
  5. Release both the mode key and the OK key -All the modes keys will flash twice indicating programming mode
  6. Enter 922 by pressing the number keys on the remote control -The selected mode key will flash twice indicating correct entry (for anything other than AUX go to step 7, for the AUX mode searching only, press and release the play key then press 1 for VCR 2 for Receiver/Tuner 3 for Amplifier or 4 for Home Theater In The Box (HTIB) - The AUX mode keys will flash twice indicating correct entry)
  7. Press and release the PLAY key, every time you do this, autoserach will try a different code, continue to do this until your device turns off. (if you weren't paying attention and you miss it, the REW key can be used to go back through the codes one at a time, and the ff key can be utilized to move forward through the codes one at a time.)
  8. To save the code press the ENTER key (below the number 9) then press the exit to return to normal operations. (the selected mode key should flash three times
  9. Turn you device on by selecting the appropriate mode and power.
Jan 19, 2009 | Yamaha HTR-5940 Receiver
Quasar vv2020 remote codes
Quasar tv/vcr 0374 0381 0035 0162
These are the only ones I found for the combo's
Mar 18, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Orion FTDV2004 20 in. TV/VCR/DVD Combo Logo
931 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
