Question about HEWLETT-PACKARD Hewlett Packard Pavilion p6620f (BM419AAABA) PC Desktop
Packard Bell Imax X3414 wont boot? One long continuous beep. Help please running Vista
I have a challenge for you experts.A friend ask me to see if I could repair his computer he was given by his mum that was in the atic for at least 6 month (Packard bell i design 190) I put all the cables...
WOW, this sounds so familiar, try changing the CMOS battery, I got the same exact error mess in a old packard bell i refurbished for a friend and a simple change of the cmos batter solved the issue, it even let me install xp with not problem,, its worth a try.... :)
Sep 04, 2011 | Computers & Internet
Can you help me my packard bell windows vista pc wont boot up everytime i press the button to turn it on it just turns itself back off, it use to go green then it went to blue and now it wont *** on at all...
Do you have the vista Windows CD? You can reload your windows fresh. Try this Also
  • Boot the computer.
  • Press F8 and hold until your system boots into Windows Advanced Boot Options.
  • Select Repair Cour Computer.
  • Select a keyboard layout.
  • Click Next.
  • Login as an administrative user.
  • Click OK.
  • At the System Recovery Options window, select Startup Repair.
  • Oct 21, 2017 | Packard Bell (190169) Power Supply
    My pc powers up but wont boot up and has no beep also no power to my key board
    I have a Packard Bell motherboard MS-7301 VER:1.0 The computer does not boot up. The computer is about 4 years old model type UTOW - CUB SERIAL # 049924520227 Any solutions?
    Jan 21, 2011 | Packard Bell (181678-03) Motherboard
    How do i upgrade my packard bell imax mini n3600? i want it to wrk better as a gaming computer
    This is a media PC and not meant for hard gaming. My advice don't waste your money on this PC to turn it to a gaming PC. The components are all built-in onto the motherboard except for the RAM & HDD.
    May 31, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
    Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
    Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
    Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
    Packard Bell imedia 5077 bios 3 beep problem
    find what type of motherboard you have then
    look for the beep code information here
    http://bioscentral.com/
    Sep 21, 2008 | Computers & Internet
    BIOS beep codes on packard bell home pc
    You need to check your RAM, make sure it is seated properly.. this should fix the problem!
    Sep 18, 2008 | Packard Bell Easy One Silver 2101 Notebook
    Microsoft Lifecam VX-3000 Sound problems
    Right Click the volume icon in the taskbar.
    Select RECORDING DEVICES, Select the device you wish to use. Click properties.
    Ensure it says ENABLE (use this device).
    Then Click the ADVANCED TAB at the top and make sure it is set to "ALLOW APPLICATIONS TO TAKE CONTROL OF THIS DEVICE".
    Then open the Messenger software you use and click the tool tab. Then click the Cam/Audio option.
    Make sure you have the correct mic/cam selected.
    Sep 13, 2008 | Microsoft LifeCam VX-3000 Web Camera
    Packard Bell error signals
    here is a list of packard bell beep codes with meanings
    http://www.uktsupport.co.uk/pb/mb/phnxcode.htm
    Hope it helps you
    Nov 13, 2007 | Packard Bell Easy One Silver 2101 Notebook
    HEWLETT-PACKARD Hewlett Packard Pavilion p6620f (BM419AAABA) PC Desktop Logo
    29 people viewed this question
    Top HEWLETT-PACKARD Computers & Internet Experts
    Michael Vincent Cruz
    Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
