Question about Radio Communications
Cannot get the cb's channel selector to go either up or down.
This is a cb radio that lives in my motorhome.I cannot get the cb's channel selector to go either up or down to bring in the various channels,it remains fixed on one channel.the knob turns ok. and I can hear a background hissing from the speaker and there's power to the unit,and oh yes it has worked fine in the past,the antenna is hooked up and I have not tried to make any adjustments on it to bring on this problem.
any help would be greatly appreciated.
Thank You
  • Arthur Strader Mar 13, 2009
    The CB Radio was made by "Realistic" it's Model number is "TRC-430. I'm guessing that it was originally bought from "Radio Shack"? as it came in the motorhome I bought a year ago.I hope this helps.Thanks again.
  • james morgan May 11, 2010
    which radio is it model number???
  • 40 Answers
Channel selector does not work
Defective IC101, SW5, SW6, SW7, SW8
this is in the service manual if it was working i would think broken solder joint first. if you cant fix it i can.
Posted on Mar 13, 2009
Channel selector only works going down not up
there is two common connections to the channel selector
up and down
resolder the channel sectors pins
then it will work
its a broken connection to a common pin
if its not a break on the selector to the PLL data bus then
use DE-OXITE 50 {this one no others for selectors} look on ebay for it
Oct 07, 2014 | Magnum DeltaForce CB Radio
I get a bleed through in the AM/FM/XM radio in my motorhome when I transmit the CB. I replaced the mount bracket, ran a new ground wire from the base to the metal frame of the motorhome, but still have...
check the SWR's if there high they will cause problems .. make sure your coax is 95%or better shielded type and have someone check the swr on the antenna should be free at any good radio shop..
Sep 24, 2011 | Cobra 75 WX ST 40-Channels Handheld CB...
Channel dial only works one way going down channels and will not go up any ideas how i can get this working please
that is an odd issue. each slot on the dial is a specific freq. meaning theyRAM h spot the non clicks I to is always going to be that channel. the channel selector sounds like it is bad. you can try contact cleaner on the selector knob. if that doesn't fix it you need to replace it.
Jun 30, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
My cb cobra 29 ltd problem is channel 1 is ok but channel 2 not receive
Did you have someone get on channel 2 to see??? Maybe channel 2 was quiet and channel one had better receive or noise.. You never know until you check it with another radio. That is NOT a common issue at all on those radios. Better off doing that test.
Dec 28, 2010 | Cobra 29 LTD CB Radio
How do get my magnum cb on 19
Its very easy on this radio because it has a built in frequency counter. I can't remember off the top of my head but its most likely band letter A, then turn the channel selector to 19. If you are on the CB channel 19, the frequency counter will read 27.1850.
If band A channel 19 is not 27.1850 then leave the channel selector on 19 and flip through the band letters until it reads 27.1850. once you have found it, that letter is the CB band. channels 1 - 40 of the cb band.
Nov 15, 2010 | Magnum S6 Base CB Radio
Channel selector , part of digit burned out!like on ch. 19 it looks like 13!!
The LED channel displays on these radios are replaced as a unit. Look on eBay for replacements. They are usually available quite cheap and are rather straight forward to replace.
Jan 25, 2010 | Cobra 29 LTD CB Radio
Where can i get channel selector for deltaforce 10 meter radio
cb shop temple, tx on yahoo search can see what i can find.
Mar 04, 2009 | Magnum DeltaForce CB Radio
Radio Communications Logo
114 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
