Question about ViewSonic VG1930WM LCD Monitor
Our viewsonic monitor tilts forward. how do we tilt it back?
Is it adjustable back and forth not just up and down?
  • ranierimj Mar 12, 2009
    It is a ViewSonic Monitor purchased thru Dell c/o Genco. Vendo item # VG1930WM
  • Greg Carson May 11, 2010
    Hi Ranierimj,
    What is your monitor make and model number?
    Scholar:
  • 26 Answers
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Posted on Mar 12, 2009
How do I adjust the screen tilt and height? HELP!!!!!!
Hi, Here is what I was able to find out about your monitor from ViewSonic. There is no manual available on their website.
I have two ViewSonic monitors that are very similar to the one you have.
Here is what I can tell you. The monitor, although it does not seem like it can, be tilted front to back.
If you grip the monitor screen on the side edges (left and right) and 1/3rd the way up and twist it either away or toward you, it should tilt. It is a little stiff, just go ahead and tilt it. As far as adjusting the high. That, I'm sorry to say cannot be done.
I hope this helps you.
Best Regards,
Mark
Feb 15, 2011 | ViewSonic VA1912wb 19" LCD Monitor
How do you tilt screen back
just get hold of the top and bottom of the monitor and push it back or forward.
If it wont tilt with minimum effort, it may not have a tilt function, or it is broken, i have never had any problems with any monitor
Aug 26, 2010 | LG 22" FLATRON LCD Monitor
Can I change the angle of my viewsonic screen
Here is what you can do ergonomically;
Height adjustment range 8.1cm / 3.2", tilt, swivel range 360º
So, yes you can tilt the monitor's angle, but if you are asking about the viewing angles then no you cannot.
May 09, 2010 | ViewSonic VA1930WM LCD Monitor
My monitor won't stay in any "locked" position. It is either tilted too far forward or tilted too far back and is hard to view in either position. Can I adjust in any way?
You have broken pins in the spring loaded stand, the pins are made of plastic, this very cheaply made stand from HP. You need to get new stand.
Nov 30, 2009 | HP L1702 17" LCD Monitor
I just purchased a 2007 jeep liberty sport
I have a 2005 Jeep Liberty and the smae lever that tilts the seat also moves it forward and back. Press forward or back on the switch. Also check for blown fuse or a loose wiring connector under the drivers seat. Good luck, Techjoel
Jun 07, 2009 | 2007 Jeep Liberty Sport
Tilting Problem with monitor
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Jun 06, 2009 | Acer 22" X223w LCD Monitor
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
HP f1905e tilt and Height adjustment
I figured it out! Just takes a phillips screwdriver and a 5/16" open end wrench to tighten up some nuts inside the plastic housing. The plastic housing doesn't come off with the screws, but has to be slightly pryed up to release the little plastic catches. Be careful though, you don't want to break the plastic tabs. It's ok to break maybe 1 because there are several to take up the slack. At first I thought it was the nuts that are 1/2" (there are two that are close to 2 springs. But that was just for the tilt forward and backward. Actually there are 4 nuts (5/16") that need to be tightened. Don't over tighten or it will not tilt at all. I took photos of the disassembled base. If you have skype, then skype me at "golfbob" chino hills, and I can send the pics or talk you through it. Good luck.
Jan 11, 2008 | HP f1905 19" Flat Panel LCD Monitor
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
ViewSonic VG1930WM LCD Monitor Logo
1,340 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
