Question about HP Pavilion dv6000z Notebook
Memory upgrade in HP Pavillion dv4130us laptop
1.How do I remove battery? The slider doesn't seem to unlock or release the battery.
2. How do I identify which panel to open to remove the original chips and replace with the new chips?
  • 2,229 Answers
In addition to the slider, you will see a small slider that has a picture of a lock on it. You need to slide it to the unlocked position before trying to release the battery.
As I recall, there are 2 panels on the bottom of the machine. One should have a graphic representation of memory, but every manufacturer seems to use a different picture. Best solution--open one and if that's not it, try another! You can't hurt anything.
Posted on Mar 12, 2009
Installedmemory now pavillion ze4610 just beeps and shuts down.
Make sure your battery is removed, unplug, reseat memory mods, make sure they are inserted fully. I assumed the 512MB are used? New? There is no reason , that I can come up with, they should not work? I have upgraded many memory mods without incident.
Dec 03, 2012 | Computers & Internet
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
How do you remove the battery?
There's usually a small latch on the underside of the laptop marked with a small battery icon. Push the latch to the side and the battery should pop out enough for you to grab a corner of it. Sometimes there are two latches, in that case they will be numbered for the proper order to trip the latches to remove the battery.
Good luck!!
Nov 19, 2009 | Computers & Internet
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
Want to upgrade hp compaq nx6120
To upgrade a HP (Compaq) NX6120 you will require -
  • T8-9 mm screw driver
  • P1 Philips-head screw driver
Q.1. Increase the RAM size. (Can you please guide, what is the maximum size it can support w/o any problems & which make & model to buy)
A.1 To Upgrade the memory you require to purchase a
333 MHz, 200-pin, PC2700, DDR SDRAM SO-DIMM with the Maximum size of 2GB.
The memory can be purchased from any good local computer store as of 27/03/09 the price on Buy.com for 1GB stick was $47.99
Installation
Important Notes
When handling a RAM, all way hold the edge of the RAM, also use care to prevent touching the RAM on the motherboard. Touching the RAM could damage or destroy the RAM.
  1. Turn off the laptop.
  2. Disconnect any USB/Power cables attached.
  3. Slide the battery lock to the unlock position.
  4. Slide and Hold the battery release to the unlock position.
  5. Slide the battery out from the laptop.
  6. Loosen the captive P1 Philips-head screw that secures the memory cover to the bottom of the notebook.
  7. Using you fingers gently lift the memory cover from the edge of the laptop, at the finger groves on the laptop case and remove it.
  8. Push both arms outward simultaneously to release the expansion memory board to the spring tension position.
  9. Grasp the edge of the RAM and pull gently to remove it.
  10. Place the RAM in a static dissipative bag
  11. Take the Ram from the static dissipative bag
  12. Grasp the edge of the RAM and align it to the empty board receptacle.
  13. Gently press the RAM down to latch the arms.
  14. Slide the battery cover back into the clips on the laptop.
  15. Tighten the captive P1 Philips-head screw.
Q.2. Increase the Hard disc capacity. (Can you please guide, what is the maximum capacity of hard disc it can support w/o any problems & which make & model to buy)
A.2 The maximum hard drive all depend on the type of windows you will be installing and the chipset on the Laptop. The standard chipset for the HP NX6120 is Intel 915GM and does not any limit set
To found out what type of chipset is installed open Device Manager using the steps listed for your particular operating system.
  • Windows Vista: click Start » click Control Panel » click System and Maintenance » click Device Manager
  • Windows XP: click Start » click Control Panel »System icon » click the Hardware tab »Device Manager
  • Windows 2000: click the Start button » click Settings »Control Panel » double-click the System icon » click the Hardware tab » click Device Manager
  • Windows 95, Windows 98, Windows 98 SE, and Windows Me: click the Start button » click Settings » click Control Panel » double-click the System icon » click the Device Manager tab
  • Click the + sign to expand the System devices entry.
Look for the chipset name in a string similar to the following: "Intel® 955X Memory Controller Hub - 2774". In this example, the chipset is an Intel® 955X Express Chipset.
If the chipset is in the 800 range please visit Intel website to install Intel® Application Accelerator.
http://www.intel.com/support/chipsets/iaa/sb/cs-009293.htm
I have included a list below of all of the main operating systems with their HDD support
  • Windows Vista - 2TB,
  • Windows XP - 2TB,
  • Windows 2000 - 137,
  • Windows Me - 137,
  • Windows 98 SE - 137,
  • Windows 98 - 80,
If you are install any other Operating Systems please see to OS guide.
To Upgrade the memory you require to purchase a 2.5" (inches) IDE HDD also know as a 2.5" (inches) PATA HDD with the maximum size above.
HDD can be purchased from any good local computer store as of 27/03/09 the price on Amazon for 250 GB was $79.61
Installation
  6. Loosen the captive P1 Philips-head screw that secures the HDD cover to the bottom of the notebook.
  7. Loosen the captive P1 Philips-head screw that secures the HDD.
  8. Grasp the Mylar tab and pull the HDD toward the outside edge of the enclosure.
  9. Lift the HDD out of the bay to remove it.
  10. Place the HDD in a static dissipative bag
  11. Take the HDD from the static dissipative bag
  12. Place the HDD in to the HDD bay with the connectors match up to connectors on the in the enclosure
  13. Gently push the HDD toward the inside of the base enclosure until the connector is seated.
  14. Tighten the captive spring-loaded P1 Philips-head screw that secures the hard disk drive
  15. Slide the battery cover back into the clips on the laptop.
  16. Tighten the two captive P1 Philips-head screw.
Q3. Want to Install DVD writer. (Can you please suggest whether it supports it or not & which make & model to buy)
A3. Yes the HP NX6120 does support DVD write but unlike the another question the DVD drive must be the pre fixed to suit the HP NX6120.
A DVD can only be purchased from HP or at selected online store as of 27/03/09 the price on getpartsonline.com for a
Dual Format Laptop DVD±RW Drive was $99.99
Installation
  8. Remove the T8-9 mm screw that secures the optical drive to the base enclosure.
  9. Insert a paper clip or thin metal rod into the manual release hole on the front bezel of the optical drive and press firmly.
  10. Grasp the side rails of the drive tray to pull the optical drive out and remove.
  11. Push the drive tray back into the optical drive
  12. Insert the optical drive into the base enclosure until the connector is seated.
  13. Replace the T8-9 mm screw that secures the optical drive to the base enclosure.
Mar 27, 2009 | HP 378248-001 keyboard for Compaq nc6110,...
The screen only give a light blue window
have you made any system upgrades or changes
like memory or OS
Can you get into safemode by pressing F 8 constantly while in restart
Jan 19, 2009 | Computers & Internet
Wanting to upgrade the memory on a hp pavillion a6220a
Standard Memory:
256 MB or 512 MB or 1 GB (Removable)
Maximum Memory: 2 GB Memory Expansion: 2 Sockets
256MB Memory (PC2-5300) 396519-001, PX974AA, PX974AT KHEW974
512MB Module (PC2-5300) 396520-001, EK477-69001, PX975AA, PX975AT KHEW975
1GB Module (PC2-5300) 398038-001, PX976AA, PX976AT KHEW976
You can upgrade your system to 2GB MAX
Your memory type is PC2-5300
Please be sure to get the right memory (above listed)
Have a great day
Pablo :-)
Let me know if you have some questions about this issue...
Oct 22, 2008 | HP Computers & Internet
Pavillion DV1000 will not boot
may be two things 1. your powersupply unit is gone or 2. your motherboard
Jun 11, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
