Question about Panasonic Audio Players & Recorders
I have a 90's vintage Panasonic radio/cd/tape combo unit that I have enjoyed since new. Recently the multi cd unit quit functioning. That unit is separate from the radio and the model is SL PK345. It will pick up the cd but than just put it back down and rotate to the next disc and repeat the process. Is there any fix for this or should I look at replacing? If so, what can I replace it with?
No answer after a year? Must be a really complex problem or some geek would know how to fix it!
Actually if you just unsnap the cover over the area where the disc plays (push in the two tabs at the edge and rotate upward) and use a swap damped with alcohol to clean the small plaster laser cover (the small part that jumps up and down) you will be back in business.
Posted on May 24, 2010
  • tyrianwm May 24, 2010
    Probably meant plastic, didn't he?
I have a R 91 Phillico cadatheral. It has connections for a tape player but it is not in the unit. How does this work?
The tape player is an external unit that is connected where indicated to play tapes through the radio.
Sep 14, 2012 | Vintage 1930's Replica Cathedral Radio and...
Tape recorders.
Most tape problems would be mechanical in nature. I am venturing a guess that the belt(s) are cut. If your brand/model uses two (2) separate motors, then either both belts are cut (unlikely) or the regulator circuitry powering these motor(s) are defective. In some instances, the logic circuitry (especially those with dubbing features) maybe at fault.
Corrective procedures would entail opening the unit for a look and see. This of course would require that you be familiar with electronics circuitry & mechanical components, use of a DVM and possibly even soldering. Should you be uncomfortable going this route, perhaps it will be to your advantage to seek the services of a qualified professional.
Incidentally, should the downtime and cost of repair be no longer economically reasonable, then perhaps purchase of a new unit might have to be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 25, 2008 | Audio Players & Recorders
Hello, my remote for my Panasonic DMR-EZ47V DVD Recorder / VCR Combo recently stopped working, and whenever I press a button on the remote, I get a message on the display as "RC1" I'm guessing...
Actually, you are sort of correct, in a sense, RC1 means remote command mode 1 (the default mode of your combo unit). There is one way you can try to fix this:
Remove the batteries from the remote, press any button on it to clear its existing memory buffer, then re-insert them or replace them with new ones. While unit is on (no DVDs or tapes in it), point the remote at it - press and hold 1 and ENTER/OK buttons together for 10 seconds, then release.
This should (in most cases) restore full remote command operation to your combo unit - if when you press a channel button on it, and the unit's front channel changes, the remote is now functioning as it is meant to.
The good news is this will constitute any workshop repairs or costs (except perhaps new batteries for the remote if required).
I hope this helps a bit.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I require a user manuel for a Panasonic cd/double tape/radio model RX-ED70 EB-K FS61OE4750 CLASS 1 Panasonic Laser Product . Many Thanks for your help. bwesmith
You can get your manual for free from here:
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/RX-ED70-_J
Enjoy
Aug 13, 2010 | Panasonic Audio Players & Recorders
Nothing works
I've had Panasonic and other radio/CD/tape players quit reading CDs after the laser head lost alignment. I assume the radio is still working. The cost of a tech realigning the laser is likely more than the cost of a replacement. Lasers may be knocked out of alignment or drift off on their own.
Multipurpose units generally don't emphasize quality. With the low price of DVD/CD players, you may have a large radio now that wil fit on top of a new DVD player.
Aug 06, 2009 | Panasonic Televison & Video
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Panasonic XRB RXCT950 Boom box radio,tape and plug in CD player
It sounds like your unit has a LOT of broken solder connections and dirty potentiometers. Unless you are VERY good at soldering and want to invest about 1 to 2 hours of time, I would toss it and start fresh.
Jun 16, 2008 | Panasonic Audio Players & Recorders
No sound from CQ-1305U car CD/stereo
You may have one of this two problems:
One of the speaker wires is grounded to the chassis.
Or your car may have a factory amplifier between the radio and the speakers.
My suggestion is to rewire the speakers lines
Dec 25, 2007 | Panasonic CQ-DP383U CD Player
Panasonic Logo Constantly Across Screen
With the Power On, hold down the Play/Repeat On button for 5 seconds. This will toggle the 'feature' on and off.
Nov 06, 2007 | Panasonic PVQ-M2509 Combo
159 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
