Question about Garden
Sprinkler zone has low pressure
One zone in my sprinkler system has low pressure. Changed out the control valve and was the same. No sign of broken line.
  • 21 Answers
It is Quite possible you may have too many heads on the line with the low pressure. you may also have an undetected leak at the nipple/riser to sprinkler connection,or elsewhere in the line underground. there may also be a piece of glue or other material caught in the screen in the sprinkler body.
Posted on May 20, 2014
  • 132 Answers
SOURCE: sprinkler
you need to get a small piece of very thin wire or a fine needle and push in the holes while turning on the sprayers on are you sure the pump is working that makes the water come out i am hoping the water tank is full to start with
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: How can I charge the AC system is possible to install a low pressure valve?
THERE SHOULD BE A HIGH PRESSURE PORT LOCATED IN FRONT OF THE RADIATOR..WITH A RED CAP ON IT...THATS THE ONLY PLACE YOU CAN CHARGE THE A/C..THAT WHAT A DEALER MECH TOLD ME.......YOU MIGHT HAVE TO FIND A ADAPTER FOR THE FITTING......IF YOU FIND ONE LET ME KNOW......
Posted on Mar 15, 2009
  • 20 Answers
SOURCE: valve pressure renault laguna
you must make sure the senser is the correct one.each wheel senser has to be correct.they are not the same.i think they are colour coded.say rear wheel wont work on front etc.sometimes inflate pressure to around 45psi on side that is faulty then let pressure down to correct level resetts the senser.otherwise think its renault dealer to reset computer
Posted on Jun 07, 2009
  • 41 Answers
SOURCE: air conditining not working properly, changed
check your orifice tube if its plugged up it will give you a high reading.
Posted on Jun 24, 2009
roniecon
  • 6826 Answers
SOURCE: 94 civic 1.5 air condition won't blow cold,
Are you using gauges?What are the pressures?And are the cooling fans coming on when ac is on?
Posted on May 17, 2010
Testimonial: "Changed compressor and cool as can be in Arizona"
Rainbird troubleshooting
It is likely the water pressure is low (perhaps a leak in the irrigation pipe) or simply the spring is stuck. Wonder if you have more than one sprinkler connected and if all are having the same problem.
Jun 13, 2014 | Garden
Zone 1 stays on all the time even while other zones go
Sprinklers and valves can get clogged. First turn off your controller, then remove Zone 1's valve... see if you can determine if it is clogged. Then clear the clog or replace the valve.
May 25, 2014 | Rainbird Rain Bird Esp-sm3 3-station...
One zone has low pressure
Try getting information from the manufacturer.
Apr 12, 2014 | Garden
I have one zone in my sprinkler system that has low pressure. I have changed the control valve and its the same. No signs of broken lines.
If it is a anti-siphon valve remove the anti-siphon cap and let it rip. Remove cap on adjacent valve and let it rip check to be sure the gieser is identical. If so let it run for a long time the leak will eventually show up. Because if it worked before and doesn't work now it has a leak. Water takes the path of least resistance. I have had them access the landscape drain before and you the leak didn't appear until it emptied at the street or followed a gopher hole a few hundred feet before surfacing. Listen carefully you will probably hear it.
If water just dribbles over the anti-siphon portion with cap removed it is still not opening flow control know may be turned down. In fact I would check to ensure this isn't the entire problem turn ir counter clockwise until it stops. This is the round know in the center of the valve.
Apr 21, 2013 | Garden
The timer no longer plays all 3 programmed zones. It play only one.
Three things to look for:
1) If sprinkler turns on-off but doesn't advance to next zone, then Sprinkler Valve is suspect, and timer is good.
2) If sprinkler stays on all the time, or never turns on, then Timer is suspect.
3) If sprinkler turns on-off, but leaks when it's supposed to be off, then Sprinkler Valve is suspect, and timer is good.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jun 24, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Garden Logo
698 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
