Question about Sony VAIO VGN-T350 Notebook
I'M NOT SURE HOW I DID IT, BUT I SWITCHED THE RIGHT SIDE OF MY KEYBOARD TO A NUMERIC PAD. I CAN ONLY TYPE LETTERS BY HOLDING THE "Fn" key. How can I switch the right side back to letters as the default?
  • ivykucine Mar 12, 2009
    Thank you so much. Perfect!!
  • 370 Answers
"Fn" Key and "Num Lock" key at the same time should do the trick.
Posted on Mar 12, 2009
The function key for the numbers on the keyboard i can't seem to stop it. When I want to use the letters i have to use the blue funtion key
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jun 27, 2014 | Acer Aspire One Netbook 8.9" Notebook
My acer travelmate 2410 the letters I o p j k l are typing the numbers 1 to 6 Instead
Has anyone spilled any liquid onto the keyboard?
This is a common indicator as to why the keyboard gives wrong character inputs.
If this is the problem, the keyboard will need replacing
If this is not the case try pressing the FN and NUMlock keys together
Jul 25, 2011 | Acer Computers & Internet
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
Hi There. Not sure what key i've gone and pressed. The majority of the letters/numbers on my keyboard all work in first hand english but some of the keys where i have an option with a smaller blue number...
You have turned on the numeric keys on your laptop. It is turned off/on by the following.
Press the Num Lock key. If nothing happens, try Shift+Num Lock.
If the text Num Lock is shown in a different color, find the matching-color key, such as Alt or Fn. Then press that key in combination with Num Lock.
You’re successful when the Num Lock light comes on. At that point, the keyboard has switched into numeric keypad mode.
Read more: http://www.dummies.com/how-to/content/the-hidden-numeric-keypad-on-your-laptop.navId-323018.html#ixzz0vfEI4Odm
Aug 04, 2010 | Computers & Internet
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Toshiba Satellite A-105 doesn't have a Numeric
Hold down the FN key at the bottom left of the keyboard & press either (scr) (prt scr) or (sys rq) key witch is at the top right hand side of the keyboard, There indicated by a white square round them.
Jan 16, 2010 | Toshiba Satellite A105 Notebook
Keying numbers instead of letters whun num lock on
Check 2nd Function keys. The problem you describe is normally a Fn +numlock keystroke on most systems
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Sony VAIO VGN-T350 Notebook Logo
182 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
