Question about Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X4 605E GB/6GB) (DDPCEZ331)
Inspiron 2305 Bootmgr is missing error message
4 Suggested Answers
  • 2291 Answers
SOURCE: I have a Dell Inspiron One 2305 with windows 7 it constantly crashes and comes up with a blue screen also when it boots up i get an error message for the catalyst control center.
Use a system utility software like RegInOut to fix blue screen error. It will fix corrupt registry files & windows file.
Hope it works for you.
Posted on Dec 28, 2011
bronk50
  • 27725 Answers
SOURCE: dell inspiron one 2305 turn off by it self?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps you
Posted on Mar 09, 2012
Geekman
  • 32281 Answers
SOURCE: Dell Dimension 4550 BOOTMGR is missing error message
To repair missing orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
Posted on Jul 10, 2012
Bootmgr is missing what should i do?I down loaded the bootmgr what should i do...
It is presumed that you are getting the following error message:
"Bootmgr is missing Press Ctrl+Alt+Del to restart"
The error generally pops up when the boot sector is damaged or missing. To troubleshoot the issue, you can refer to the instructions mentioned on the following link:
http://support.microsoft.com/kb/2622803
GuruAid.com
Feb 06, 2015 | Computers & Internet
BOOTMGR is missing,
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
  3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
    Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
  5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
    The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
  6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
    Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
  7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  8. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
  9. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
SysFlashwww.sysflash.com
May 29, 2013 | Lenovo IdeaPad S10-3t 0651 Notebook
Dec 28, 2011 | Dell Inspiron One 2305 Desktop Computer...
As soon as computer is turned on the message bootmgr is missing press ctrl alt del to restart
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
i strongly suggest formatting your hard disk drive, and reinstalling the recovery CDs
if you dont have them, get Dell to send them to you -- it will cost you money
Oct 16, 2010 | Dell Inspiron 1545 Notebook
Bootmgr missing error while installing XP
Dear sir,
plz use this link to solve your probelm,
http://support.microsoft.com/kb/927523
I hope this help.
Thanks For YOur Time,
Apr 10, 2010 | Dell Inspiron 530 Desktop Computer
I have an inspiron mini 10 and it is saying BOOTMGR is missing when I hit ctrl alt del to restart the same error message comes up
I would do a Windows Repair. Find your green Dell CD that shipped with the computer and boot to that. You may need to enter Setup to change the boot order.
Instructions here: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
This will not harm your data, it repairs just the operating system.
Mar 08, 2010 | Dell Inspiron Mini 10 Notebook
Will not open. states BOOTMGR is missing
Follow this link for instructions on how to fix.
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Oct 07, 2009 | Dell Inspiron B130 Notebook
Describe your Dell "Inspiron
The best solution is to re install your OS.
Jul 06, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X4 605E GB/6GB) (DDPCEZ331) Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
