Question about GE GBS22KBS Bottom Freezer Refrigerator
Clicking sound - not cooling
Our GE refrigerator model gbs22kbsbww (bottom freezer) is clicking every 3 seconds for hours and the compressor does not come on and it is not cooling the upper frige or the lower freezer, and very slowly everything is getting warmer. I unplugged it for 10 minutes to let it "reset" but when I plugged it in again the clicking continued.
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
Posted on Oct 01, 2009
  • 400 Answers
You should change the starter relay which is the clicking noise you hear each time the compressor tries to come on.
Posted on Mar 12, 2009
Freezer not working
If the freezer is not cooling, then problem relates to compressor.but still wait more 12 hours and see if it starts cooling.Basically it takes approx 24 hours to regain its cooling, once its unplugged for few hours and then plugged in.---------- So once again check after another 12 hours and see if you notice cooling.But if there is no cooling then yes its compressor issue.-----------
If freezer will not start cooling, then fridge will also not start.------------
Click this link below and get more details:---------
http://technoanswers.blogspot.com/2011/08/freezer-taking-too-long-to-cool-or.html
This will help, thanks.Helpmech
Oct 17, 2011 | GE GTS22WCP Top Freezer Refrigerator
GE refrigerator bottom freezer Model #PDS22MBSACC has been clicking for hours, is there something I can do to fix it, or do I need a new compressor? Also the refrigerator and freezer control numbers are...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Pds GE Profile Bottom-Freezer Drawer...
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
4. Wait one hour.
Try this and let me know.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
Refrigerator and freezer will not cool. motherboard replaced. clicking sounds. fan is running.
YOU NEED TO TRY WHAT IS CALLED A 3 IN 1 KIT THAT GOES ON THE COMPRESSOR VERY EASY TO INSTALL
Dec 14, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Clicking sound
it sounds like its the compressor packed up, bit you could be lucky and its just one of the thermostats stoped working,,,
Nov 19, 2009 | KitchenAid Architect KBRA20EMSS Bottom...
Not working
If the clicking sound is coming from the back of the refrigerator at the compressor, you have a faulty starting device or faulty compressor. The compressor has a 5 year warranty so call to have someone out if you can.
Feb 01, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Frig and feezer stopped working
It sounds like the overload and relay on the compressor.If the problem isn't that then you need a compressor.
Eeggman
Nov 07, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
GE GBS22KBS Bottom Freezer Refrigerator Logo
286 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
