Question about Thetford Refrigerators
Adjust door on Norcold N841 - Thetford Refrigerators
2 Suggested Answers
SOURCE: My norcold N841 will not cool on AC or Gas it has
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Posted on Sep 28, 2009
Thetford gas igniter burns but ignition is not seen by control unit
Without the make & model...
the only answer possible is a "TYPICAL" SWAG: Looks like NORCOLD is most likely your manufacturer (although I've also seen U-Line).
SPARES are good to have... (now you understand).
On-Line parts abound everywhere... It is likely an "electric"
(because of your control board statement).
I'll put up sample Pix from Amazon & eBay.
http://www.ebay.com/sch/i.html?_nkw=Norcold+Refrigerator+Thermocouple
Your THERMO-COUPLE (flame monitor)... same (type) thing that always fails on our water heaters... typically costs $6 if you are buying one in advance... up to $24 (twice that for the "Refrigerator versions" $12 to $48) in you hour of need... Unless you call a "service" (plumber) person... Then just start adding on those ZEROs.
These also can use an INTERRUPTER (same price range)...
Buy them both... As you can tell... they are good spares to keep around (I always buy a NEW thermo-couple & put it on a nail
with a "NEW water heater installation (keeps evil spirits away).
I'd recommend you post the complete make, model & year...
Defective GAS appliances can be quite deadly... even if the work is done properly... improperly the sky (is quite literally) the limit...!!
Could NOT more strongly URGE... Buy and USE a good carbon-monoxide monitor/alarm.
Truly a LIFE-SAVER.
All gas utility companies will (or used) to QUICKLY send out their representatives to inspect/light gas appliances..
Historically this was always a FREE SERVICE...
(but sadly that the extent of my knowledge... HISTORIC).
Be safe... Comment me back if you need:
(never test for leaks with a match... My grand-daddy taught me that (course hair & eyebrows grow back... MOST of the time).
Norcold Refrigerator Thermocouple
Apr 11, 2016 | Refrigerators
1996 Komfort trailer, model 9182 Norcold fridge. Works great on 110V, recently it suddenly quit on the gas mode. It tries to light and flame flame comes on, but once the ignition sequence and sparking is...
The electrode that ignites the burner,also senses flame to keep burner going. Sounds like it's defective. I'd replace it, but take old one with you to match it up.
May 15, 2011 | Thetford RV Refrigerator - N841 Model -...
Light in refrigerator does not go out when door is closed. We replaced the switch but the light still stays on when door is closed. Can you tell me what the problem is?
To make your search simpler and understand the way to search Norcold Manuals is to always remember Norcold and Dometic models will always come up with different search names. Confused? Click here to bigin your search=> Norcold If you are unable to get results then click=> HERE Once and at top and bottom of page=> Here you may contact me for more answers to your questions regarding your NDR1292, Thanks, Sea Breeze
Mar 20, 2011 | Dometic NDR 1292 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
My norcold N841 will not cool on AC or Gas it has power and the gas will fire up
Sep 02, 2009 | Refrigerators
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Refrigerators Logo
88 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
