Question about Husqvarna 24HP 54" Yard Tractor ()
Diagram of anti rotation link - Husqvarna 24HP 54" Yard Tractor ()
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
How to replace serpentine belt on 2000 saturn L series not ion
Click on the following direct Link. It has the Serpentine Belt Diagram for the L-Series for your specific engine and options (AC/No AC etc.). It has other additonal diagrams for your future use. It also has diagrams on how to rotate/move the Tensioner Pulley/Arm to loosen and remove the Belt.
Standard Rules to Removal the Serpentine Belt:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT OR OPENING (3/8ths or 1/2 inch square opening) rotating it\moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
Standard Rules for Installing the Serpentine Belt:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2000/make/saturn/model/ls/2000_saturn_ls_drive_belt_routing_diagram.htm
Mar 19, 2010 | 2000 Saturn SL
How replace serpentine belt on 2000 saturn l
I fully realize this is the same question you re-asked later on.
I want to make sure you receive an answer either way.
Mar 19, 2010 | Saturn L-Series Cars & Trucks
How to change serpentine belt on vw passat w8 2002
Click on the following Link. It has the Serpentine Belt Diagrams you will need.
Regarding "How". The Tensioner Pulley ARM is "loaded" with a spring. The standard rule: Rotate/Move the Tensioner away from the belt contact area and towards the open area/non belt contact area. In Diagrams the Tensioner is Identified as #7 and in the next as #6. These should be rotated counterclockwise and down and to the left away from the belt. While doing this, the belt will loosen and should removed from one of the more easily "other" Pulleys.
This Link also has many other useful Diagrams for your use.
http://www.2carpros.com/car_repair_information/year/2002/make/volkswagen/model/passat/2002_volkswagen_passat_drive_belt_routing_diagram.htm
Mar 02, 2010 | Lisle Serpentine Belt Tool
How do you replace a serpetine belt on a 2002 chevy tahoe
My sincere apologies for the severly delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, however I am answering it in case you still do.
Click on the following direct Link. It has the Serpentine Belt Diagram for the 2002 Chevy Tahoe for your specific engine and options (AC/No AC etc.). It has other additonal diagrams for your future use. It also has some diagrams on how to rotate/move the Tensioner Pulley/Arm to loosen and remove the Belt.
http://www.2carpros.com/car_repair_information/year/2002/make/chevrolet/model/tahoe/2002_chevrolet_tahoe_drive_belt_routing_diagram.htm
Feb 22, 2010 | 2002 Chevrolet Tahoe
How do i change the belt on my 04 ford taurus? is there any diagrams available
My sincere apologies for the delayed response.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
After Identifying the Tensioner, always remember the tensioner always rotates/moves towards the open side (not covered with a belt) of the tensioner pulley. For example in the first diagram on the Link: the tensioner rotates towards the left, loosening the belt. Once it has been rotated/moved it can be taken off one of the other pulleys and removed.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/2004/make/ford/model/taurus/2004_ford_taurus_drive_belt_routing_diagram.htm
Jan 26, 2010 | 2004 Ford Taurus
Timing mark diagram for a 2000 daewoo nubira cdx
here are the timming marks
the other important thing is to
Rotate the automatic tensioner hex–key tab anti-clockwise until the adjust arm pointer of the timing belt automatic tensioner is aligned with the notch in the timing belt automatic tensioner bracket.
then turn engine over 2 turns and recheck marks and tensioner pointer
Nov 02, 2009 | 2000 Daewoo Nubira
Need firing order diagram for a 1982 ford f350
On the straight 4.9 liter 6 cylinder the firing order is 1-5-3-6-2-4 The cylinder from the radiator to the firewall is 1-2-3-4-5-6  The distributor rotates clock wise, (to the right) #1 is towards the brake booster and going clockwise to the right is #5 Ect
On the 6.6 liter V8 the firing order is 1-3-7-2-6-5-4-8 The cylinder on the passenger side radiator to firewall 1-2-3-4 The cylinder on the drivers side radiator to the firewall 5-6-7-8 The distributor rotates anti clockwise (to the left) #1 is towards the cylinder #5 going anti clockwise #3 to the left and towards cylinder #1 Ect.
Good luck and keep me posted, be glad to help.
Jun 25, 2009 | 1982 Ford F 350
Husqvarna 24HP 54" Yard Tractor () Logo
147 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
