Question about Viking VEDO5302SS 30" Double Electric Wall Oven With Convection Oven
Clock won't set on viking VEDO5302SS - Viking VEDO5302SS 30" Double Electric Wall Oven With Convection Oven
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
Oct 05, 2017 | Viking Ovens
How do you clear Clock/Timer on a 1-year-old Viking Electric oven (Model # VESO1302SS)?
PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m3500217_F20669.pdf
Viking RangeClocks and Timers ... the potential risk of fire, electric shock, personal injury or damage to the appliance as a result ... NEVER use aluminum foil to cover oven racks or oven bottom. ... Keep area around appliance clear and free from combustible materials, .... 1. Push and hold the "MIN/SEC TIMER" and "BAKE TIME" buttons.
Nov 26, 2015 | Viking Ovens
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Oven won't turn on can't set clock, etc
    Oven will not operate without the correct functioning of the clock, so replace ****
    Jul 15, 2011 | Ovens
    The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
    There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
    May 29, 2011 | Fisher Ovens
    How do you set the analog clock?
    My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
    Oct 20, 2009 | Viking 27" Professional Select Built-in...
    Viking oven won't turn on
    I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
    Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
    Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
    Viking VEDO5302SS 30" Double Electric Wall Oven With Convection Oven Logo
    Top Viking Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Viking Oven Expert? Answer questions, earn points and help others
