Question about Acer Aspire 5500 5570-2609 Laptop
Replace 601 internal battery forcompaq presario CQ56 LAPTOP
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Internal battery 601
Replacing the bios battery will fix that.
Jul 14, 2014 | Computers & Internet
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Jun 16, 2012 | HP Compaq 6735s Notebook
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
Compaq Presario CQ56-100SJ [XL580EAR] The clock keeps changing. I set the time, the timezone was already selected but everytime I look down, it's changed. After shutting down, it seems the time...
Assuming you don't have a virus, the laptop's internal (CMOS) battery may be bad. Apart from keeping the time current, it holds onto your machines bootlog. If the machine starts up in Safe Mode, it would likely be the CMOS battery that's bad.
Oct 18, 2011 | Compaq Presario CQ56-115DX Laptop
Where is my internal battery located on my cq62
On the Bottom of the motherboard. It is the RTC battery. Real Time Clock.
Service Manual for the Compaq Presario CQ56-115DX Notebook PC, (Free from HP Support)
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4308201&
On this page I would like you to left-click on the 5th file listed -
Compaq Presario CQ56 Notebook PC and HP G56 Notebook PC - Maintenance and Service Guide
{This is a PDF file.
It may take 30 seconds or more before the first page comes up after you click on the link. It may also take additional time for the file to fully download}
At the top of the PDF file is the page number box. It is to the left of the Down Arrow.
Go to Page 69. RTC Battery
Or alternatively use the Bookmarks menu to the left.
{Click on the + sign to the left of Removal and replacement procedures.
Click on the + sign to the left of Component replacement procedures
Scroll down, and click right on - RTC battery }
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 20, 2011 | Compaq Presario CQ56-115DX Laptop
Hey, um i plug in my compaq presario cq56-115dx and it says plugged in, not charging, can you help?
If any one of your friend have same model notebook then try with his charger if it is not working then try changing the the battery if the charger is working fine then this the time for you to change the battery.
Apr 07, 2011 | Compaq Presario CQ56-115DX Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
