Question about JVC Everio GZ-MG21 Camcorder
Everio access and charge light blinking - JVC Everio GZ-MG21 Camcorder
JVC everio won't charge or turn on. no light showing it charging or anything
Is it not doing it twice, or are you hoping for two different solutions so you can pick and choose ? Either way, it needs professional attention - take or send it to a service centre.
Oct 02, 2017 | JVC Video Cameras
JVC Everio GZ-HD3U red and green access light flashes... no buttons work as soon as i turn it on
some need the date and time set proir to using..may need to take battery off entirely and reinsert.. see if its in the menu somewhere..
Jan 11, 2014 | JVC Everio GZ-HD320 Hard Drive Camcorder
When do I know it's charged? Red blinking light means what?
its means that is charging,wait for the steady light and that is full battery already.
Jun 02, 2011 | JVC Everio GZ-MG21 Camcorder
When I turn on the camara in the Display appears the Everio logo and after that the Display doen't show anything at all. I don't have access to the Menu neither. The green light of the...
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Dec 15, 2010 | JVC Video Cameras
Is there any way to download the set-up disk for my jvc gz-hd7u
Connecting the Camera to the PC
Preparation:
Set the camera’s power/mode switch to OFF.
NOTES
• When the USB cable is connected, turning on or off the camera causes malfunctions of the PC.
• Connect the camera directly to the PC, not through the hub.
• Do not use an extension USB cable.
• Saving the wrong kinds of files in a recording medium or deleting files or folders from a recording medium can cause problems with the operation of the camera. When it is necessary to delete a file from a recording medium, delete it through the camera. Also, do not move or rename folders and files in the medium on PC.
• Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks.
1 Create a folder to back up files into.
2 Set the camera’s power/mode switch to STANDBY/ON.
3 On the camera, move the set lever to
\/ / /\ to select [PLAYBACK ON PC],
then press down.
4 Double-click [EVERIO_HDD] or [EVERIO_SD].
5 Select the folder that you want to back up, and drag & drop it into the folder you created in step 1.
SD_VIDEO:
Folder that contains video files. If you want to back up fi les individually, open this folder, and drag & drop folders such as [PRG001] one by one.
DCIM:
Folder that contains still image fi les. If you want to back up fi les individually, open this folder, and drag & drop files such as [PIC_0001.JPG] one by one.
When you have finished operation
Always follow the procedures below when disconnecting the camera, or turning off the camera/computer power.
Failing to do so may cause damage to the camera and computer.
1) Confirm that the access/charge lamp on the camera does not light or blink. (If the access/charge lamp lights or blinks, wait until it is turned off before proceeding.)
2) Double-click the [Safely Remove Hardware] or [Unplug or Eject Hardware] icon in the status bar.
3) Select [USB Mass Storage Device] or
[USB Disk], and then click [Stop].
4) Click [OK].
5) Disconnect the USB cable.
6) Turn off the camera and PC.
Sep 20, 2009 | JVC Everio GZ-HD7 Camcorder
EverioGZ-MG330
hi dear
it, suggest for us for not do it,
but if it happened just power off your camcorder , an power on again
oke, don't to worry about that
cropp
Feb 20, 2008 | JVC Everio GZ-MG21 Camcorder
My GZ-MG20 wont turn on.
You need a new battery, it has lost its ability to charge.
Jan 22, 2008 | JVC Everio GZ-MG20 Camcorder
My EVERIO doesn't respond to controls
First disconnect power source (both battery and AC adaptor) then reconnect it. If that will not correct this situation, try the following reset procedure: press and hold simultaneously for more than 5 seconds both MENU and MODE buttons. This procedure will also restore all default settings in the camera.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC Everio GZ-MG21 Camcorder Logo
112 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
