Question about Hunter Dryers
Need hunter blade iron for model 22423 - Hunter Dryers
3 Suggested Answers
canwoodjc
  • 3301 Answers
SOURCE: where can I find hunter replacement blade
this link might help you,, without a model number I can't look anything up for you ,,,, but they may be able to help you http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/
Posted on Oct 01, 2011
  • 183 Answers
SOURCE: need new blade arm where can i get it for a hunter ceiling fan model 28682
The item you need is called a "Blade Iron" - and that fan uses Hunter's P/N G2361-05 Blade Iron Set (5 pieces in set) and P/N G0858-00-860 Hardware Kit. The blades are P/N G1012-54 Blade Set (5 pieces in set).
A Parts Guide for this unit is available at http://www.hunterfan.com/uploadedFiles/HunterFan/Support/Support_Documents/98000-02-045.pdf , the Owner's Manual can be found at http://www.hunterfan.com/uploadedFiles/Support/Owners_Manuals_and_Parts_Guide/42439.pdf , and the Installation Guide is at http://www.hunterfan.com/uploadedFiles/Support/Owners_Manuals_and_Parts_Guide/site%20prep.pdf .
The Parts Guide linked above has a phone number through which parts can be obtained.
Posted on Oct 05, 2012
Where can I get a blade iron for model hunter21312 stratford fan
Call Hunter @ 1-888-830-1326. You have to order a set(5).
Jun 30, 2016 | Dryers
How can I find a blade iron for my Hunter ceiling fan model #20714?
Go to Hunter directly for the replacement part.
Jul 23, 2015 | Hunter Dryers
Need new blade arm where can i get it for a hunter ceiling fan model 28682
Oct 04, 2012 | Hunter Dryers
Fan is making noise like a bushing is rubbing
The nosie you're heraing is caused by one or more of the fan blade irons being loose, where they attach to the fan motor. Turn the fan OFF and once it's stopped spinning, check and tighten, as necessary, each loose, fan blade iron, screw. Use a Phillips head screw driver for this.
Hope this helps you solve the mystery of the whooshing noise. Thanks for choosing FixYa.
Aug 25, 2011 | Hunter Heating & Cooling
I have a Model MOD-CAT-23785-380 Ceiling Fan. I broke the arm that holds one of the blades. I need a replacement.
Davd the "arm" is technically a "Blade Iron". You can find them at most Home Improvement Centers (Lowe's & Home Depot) as they both sell Hunter Fans and universal parts.
Hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Hunter Heating & Cooling
Have a hunter 52" insignia
Diane, usually, that's an indication that one or more of the fan blade irons are loose, where they attach to the fan's motor. Unfortunately, you're going to need a tall ladder and a Phillips Head Screw Driver to reach and tighten the screws. You'll have to check each fan blade iron one at a time, to find the one(s) that are loose.
Good luck. I hope this helps you solve the problem.
Jul 09, 2011 | Hunter Heating & Cooling
I have a ceiling fan (Hunter Douglas #9700 60" Grand Lodge that was purchased in Nov 07. Almost immediately, the highest fan speed did not work so we have been using it on the medium speed. It is now...
The noise you hear may be due to a loose screw(s) in one or more of the fan blade irons. The Irons are what holds the wooden blades and connects to the motor housing. It's usually the screws that attach iron to the motor housing, that work their way loose over time.If you have a light kit on the fan, check all the tension screws that hold the glass globes,shades, whatever you have to the light fixture(s).
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Hunter Heating & Cooling
I bought two Beacon Hill Hunter ceiling fans recently. I bought them because of the promise of "whisper quiet." To my great disappointment the motors are loud. I have one on in another room...
It may not be the motors making the noise, but the blade irons that are attached to the motor are loose and are rubbing the housing.
To confirm this, turn the fans OFF. When the blades stop turning, use a step ladder to reach the fan blades and the blade irons. Using a Phillips head screw driver, attempt to tighten each blade iron screw (2 in each iron), that screws into the fan motor spindle. I suspect, you'll find one or more loose. Especially if, the lock washer wasn't installed on each screw.
Hope this helps you solve the problem. If it doesn't, contact Hunter per the instructions in your Owners Manual. As there is a slim chance that there is a manufacturer's defect involved.
May 06, 2011 | Hunter Heating & Cooling
Dryers Logo
53 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
